Author Topic: Leisure battery.  (Read 2077 times)
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
Leisure battery.
« on: 28 April 2010, 22:14:38 »
Last time i used the van i had hook up so the unused battery was full of charge. However when i parked it up again i forgot to turn the zig unit off so it's flat as a pancake!
   I'm away to a classic car meet this weekend & will have hook up. Will this recharge the battery? Do i have to flick a switch on the zig to charge or should i remove the battery & trickle overnight before i go? I have since turned the Zig off & the battery held loads of charge beforehand. This is my first van & i enjoy it but still learning. Guy. :)
Re: Leisure battery.
« Reply #1 on: 28 April 2010, 22:21:06 »
Not sure if yours has a charger built in Guy :-/ :-/
Best bet would be to trickle charge it beforehand anyway, just in case :y :y
Debs.
« Reply #2 on: 28 April 2010, 22:22:42 »
 :P Go for the full 'pikey experience' and nick someone else`s new battery! ;D
« Reply #3 on: 28 April 2010, 22:30:28 »
Deb's, I am quite shocked............. ;D ;D ;D
Amigo
« Reply #4 on: 28 April 2010, 23:02:33 »
Think the deed's already been done Debs, the battery has Mercedes stamped on it!!! ::)
« Reply #5 on: 28 April 2010, 23:12:21 »
 ;D ;D ;D :y
    • 530D M Sport, 330i Coupe
« Reply #6 on: 28 April 2010, 23:26:50 »
 ;D ;D ;D :y
 ;D
Does that mean it can only go to a Mercedes dealer to be charged?!  ;D
« Last Edit: 28 April 2010, 23:27:18 by VXL_V6 »
« Reply #7 on: 28 April 2010, 23:31:57 »
 ;D ;D ;D :y
 ;D
He is to tight to pay their prices..... :D :D :D
« Reply #8 on: 29 April 2010, 00:06:45 »
My power supply unit for my caravan isn't a Zig, but it is also a charger for the leisure battery. I always assumed that Zig units were the same.
http://www.zig-electronics.co.uk/products.htm certainly suggests that some if not all Zigs are also chargers. Can't you plug your caravan in at home & check that your battery is charging? (you'll need a round 16A to domestic 13A adapter
click
MickAP
  • South Derbyshire
« Reply #9 on: 29 April 2010, 10:36:57 »
Is that Mercedes battery a leisure battery then?
The Zig unit usually charges the battery when you are on hook up. So even if the battery is flat you should still be able to use 12v items via the battery, and recharge as well.
No harm in recharging at home though :y
Mick ;)
sexydaz
« Reply #10 on: 29 April 2010, 17:57:18 »
theres quite a few different zig units out there and some had an orange switch to power charger some had a led that was red for low or flat and green to show batt in good health,as the charger was built into some of them you need 240v to your caravan and check batt leads with a multimeter and to do right you want between 13-14 volts otherwise take one lead off the battery and see if your lights still work that would tell you if you have a charger,if its totally flat it wants a good boost and ive dealt with a few that wont come back to life..and people think caravan chargers are automatic which is how theyre described but they arent so leaving it plugged in all the time is no good,personally i charge mine for 1 day once a month to keep it topped up :y
Amigo
« Reply #11 on: 29 April 2010, 20:58:17 »
I'm pretty.....   Ok i'm pretty sure it charges automatically when hooked up to 240 volt or the genny. I'll leave it in uncharged as i've got hook up anyway, switch everything on (12 volt & 240 volt interior lighting) & see how the power gauge reads.
   TB will be on the edge of his seat biting his nails in anticipation!!! 8-)
sexydaz
« Reply #12 on: 29 April 2010, 21:38:31 »
its only a flat battery at least you havent broken it ;D
« Reply #13 on: 29 April 2010, 21:43:13 »
I'm pretty.....   Ok i'm pretty sure it charges automatically when hooked up to 240 volt or the genny.  .....
My power supply unit needs to be switched on for my battery to charge when on hook up :-/
sexydaz
« Reply #14 on: 29 April 2010, 21:53:11 »
most vans now the charger is wired to the mcb so when hooked up its on straight away older types had a charger which you could manually switch or a designated switch on the control panel
