Author Topic: Network using the mains  (Read 2522 times)
Nickbat
« on: 04 May 2010, 22:55:52 »
Thinking ahead to setting up a small network in my house, I have been toying between wireless and ethernet cable. However, I've just stumbled across this gizmo which uses the mains...
http://www.maplin.co.uk/Module.aspx?ModuleNo=48539
It would save me a lot of hassle... :y
Re: Network using the mains
« Reply #1 on: 04 May 2010, 23:23:38 »
But how secure are thay.
Lets face it, every one on your street shares the same electric supply. :-/
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #2 on: 04 May 2010, 23:24:35 »
Never used them personally but i think i remember hearing good reports about them .... plus i would think there is virtually no chance of some sod hacking your network  :y
Im going to have a look and see now  :y
« Last Edit: 04 May 2010, 23:25:51 by Mark38 »
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #3 on: 04 May 2010, 23:28:57 »
I think it will work out quite expensive compared to wireless to do a few rooms.
[img name=signat_img_resize]http://[/img]
Proz
« Reply #4 on: 04 May 2010, 23:33:38 »
Seems they come with some kind of encryption from the quick look i had on a few forums you can set up .... similar to setting up wifi .... i never thought about a neighbour using them too  :y
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #5 on: 05 May 2010, 00:24:58 »
no they don't, the house's either side should use a different phase, from the 3 phase supply, KW or another spark should be able to confirm.
Also, from memory these devices need a PIN to link them together.
Thirdly - the amount of interference these boxes chuck out upset amateur radio operatives frequencies ( forgotten the proper term for them  :-[)
Xplicit 2.0
  • Dorset, UK
« Reply #6 on: 05 May 2010, 00:49:30 »
it may not work through out the entire house... as each area is a different circuit. If the routuer is on circuit A, for example, the PC on circuit B will not be connected. its not an error on the users behalf as such, more the wiring in the building... but then again, i bet 20 years ago they never thought u would be able to run a network through the home electric rings. (my old man is a sparky and he gave me a bit of info on it when i mentioned about it)
KW
« Reply #7 on: 05 May 2010, 06:18:29 »
The problem mentioned by Xplicit above did use to be an issue if the 2 devices were on different rings (or radials), however I do believe that was addressed some time ago.
They can be secured, and Big Al is correct when he says that the properties either side should be on a seperate phase - but that doesn't mean they are.
From looking at the specs, 85Mbps is the absolute maximum bandwidth. However by the time you invoke the security and take in to account how dirty the mains could potentially be, along with the length of the cables themselves - you're probably looking at getting half that.
If it were me, I'd be running Cat6 and hardwiring.
On the plus side, Maplin do have a fairly good returns system in that providing you keep the packaging, etc then you can return whatever you buy within 14 days for a refund and it won't be a problem.
The only thing you'll "lose" if you buy them and they don't work for you is your time in buying and returning them.
I know violence isn't the answer, I got it wrong on purpose.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #8 on: 05 May 2010, 07:55:51 »
It works for us
We use it to link to a second wireless hub from the main hub that's connected to the Phone line
There is interference on the mains that gets picked up by amplifiers in the workshop closeby but not in the rest of the house
Almost famous!   www.pitchforkband.co.uk Guitar & PA Amps repaired & serviced
Ears pierced while you wait. PAT & Valve testing
« Reply #9 on: 05 May 2010, 08:06:43 »
I've been using this system for about 2 years and i've not had any problems. I will admit to being computer illiterate thats why I bought this set up and it was quick and easy to use. I've got the Netgear 200mbps (whatever that means) ones.
Pitchfork
« Reply #10 on: 05 May 2010, 08:27:48 »
Ours is Netgear too
zirax
« Reply #11 on: 05 May 2010, 08:51:26 »
You used to have issues on a seperate ring in the house, but that problem has long gone :)
I can knock a bit off the price for you though:-
http://www.scan.co.uk/Products/ZyXEL-PLA-400-200Mbps-Homeplug-with-AV-Desktop-Twin-Pack
200Mbps is as fast as it goes at the moment. If you wanted to you could stream HD over the network.
Or if you just browse the internet then there are the 85Mbps ones:-
http://www.scan.co.uk/Products/Netgear-XEB1004-85mbps-Twin-Pack-Powerline-Switch-Kit-Homeplug-inc-4-Ethernet-network-connections
Dr Richard Stephens:- "I would advise people, if they hurt themselves, to swear."
KW
« Reply #12 on: 05 May 2010, 08:54:16 »
That's double the bandwidth of a standard 100Mbps network card (pretty much all PC's/Laptops have a 100Mbps interface, and quite a few are now coming with 1000Mbps interfaces).
As far as performance goes, you have more than enough bandwidth for things like streaming video and transferring large files in a sensible time frame (the 85Mbps ones in the link would more than likely struggle with streaming video once more than one device is connected).
Radiomarko
  • Sunny Devon
« Reply #13 on: 05 May 2010, 09:38:01 »
They work very well. However they are a problem due to RF interference. They radiate wideband interference using house wiring as an antenna... this effects some FM radios and all Short Wave/AM radio if you use it. Can also break through into audio kit if there is not sufficient mains filtering/decoupling.
A disaster for us Radio Amateurs and some Mil comms, many organisations worldwide have tried to control the spread of these things with no effect. Technically speaking these devices contribute hugely to the raising of the radio spectrum noise floor - one day we will regret this electron pollution.
Tech stuff here relating to home devices and those used for networking in urban areas: http://www.rsgb.org/emc/plt.php
I hate seagulls.
« Reply #14 on: 05 May 2010, 18:17:10 »
Seconded. Except that, IME, they don't actually work very well anyway. Take the claimed throughput figures with a large pinch of salt.
You'd be much better off doing the job properly with wireless LAN or, better still, running a bit of cat 5 around the house. You'll save money, too.
