Author Topic: computer boffins  (Read 2594 times)
jack68
  • Berkhamsted Hertfordshire
computer boffins
« on: 07 May 2010, 18:31:44 »
Can anyone assist with my computer problem.  I'll try and give as much info as possible.  I had a packard bell mx37 which i gave to my mum.  She has a chap look at it and he has now installed an illegal copy of windows 7.  I know vista isn't everyones cup of tea but it came with the computer and hence isn't an illegal copy.  I have tried everything to get the computer back to the factory state and nothing seems to be working.  I know there are several people on here who know about these things so if anyone can assist i would be eternally grateful.  Feel free to pm or just add to the thread.
Jack :-/
Welung666
Re: computer boffins
« Reply #1 on: 07 May 2010, 18:37:36 »
Do you have the original discs that came with it?
jack68
« Reply #2 on: 07 May 2010, 18:42:47 »
As per new computers they don't come with any discs now.  I have the vista pass code on the rear and thats about it.
Richard P
  • Wimborne, Dorset
    • Mercedes C350
« Reply #3 on: 07 May 2010, 19:35:05 »
Borrow a Vista disk from somebody and install using the serial number from the back of your computer.
Any Vista disk that you can get hold of will do, it need not be the same version as the one that you originaly had on the computer.
Richard.
KW
« Reply #4 on: 07 May 2010, 19:40:51 »
My deepest commiserations
If your "chap" deleted all partions on the hard drive (which he more than likely did), then all the factory recovery information is now gone.
I can quite happily provide you with a copy of Vista (although please believe me when I say that was flawed from day one), although you will need to let me know what version of Vista you originally had (eg, Home, Premium, etc) in order for your PID to work with the installation disc.
Please note that "any" Vista installation disc will not work, you need the right version (Home, Premium, etc) and as it is a scrapyard bell then it will have to be OEM (which I can sort out for you).
« Last Edit: 07 May 2010, 19:42:30 by KW »
I know violence isn't the answer, I got it wrong on purpose.
StuPot100
  • Bedford
  • The forum is better than any aa
« Reply #5 on: 07 May 2010, 19:43:27 »
Just go and reboot to factory settings or go to beginning of restore point :y
KW
« Reply #6 on: 07 May 2010, 19:46:58 »
The OP has already stated that factory restore no longer works, and that's more than likely because the restore partition was removed when 7 was installed.
« Reply #7 on: 07 May 2010, 19:47:43 »
Not possible if the guy has done what KW mentioned.
Richard P
  • Wimborne, Dorset
    • Mercedes C350
« Reply #8 on: 07 May 2010, 19:57:42 »
Any OEM disk will work. These OEM disks contains all versions of Vista in that bit version (ie, 32-bit or 64-bit). It is the product key that determine what version of Vista the disk will install. An OEM version gives you ALL flavours of Vista, it's the key that determines what you get.
On the other hand if you have a Manufacturer's disk (ie Dell) it only lets you install the version that they sold you, and it usually includes drivers for your particular machine.
Richard.
KW
« Reply #9 on: 07 May 2010, 20:07:15 »
No it won't.
Not all of them do, in fact I have yet to see an OEM installation disc that offers anything other than what the computer shipped with.
Richard P
  • Wimborne, Dorset
    • Mercedes C350
« Reply #10 on: 07 May 2010, 20:16:34 »
I resolve problems like this on a daily basis and I use the same OEM Vista disk every time. I have yet to have an installation fail.
Richard.
KW
« Reply #11 on: 07 May 2010, 20:32:06 »
Richard.
At this point I'd say your OEM installation disc is not what the public gets.
If Joe Public is going to get an installation/recovery disc, then it is tied to the manufacturer of the hardware (eg, my son's Toshiba installation disc will refuse point blank to install on anything other than a Toshiba machine).
Richard P
  • Wimborne, Dorset
    • Mercedes C350
« Reply #12 on: 07 May 2010, 21:07:45 »
What Joe public gets depends on what Joe public bought. If Joe public was daft enough to buy a dell or any other branded computer he or she will have received an installation / recovery disk (if they received any disk at all). However if Joe public bought his or her computer from a company like mine, he or she will probably have received an OEM disk. I repeat my earlier post:
Richard.
KW
« Reply #13 on: 07 May 2010, 21:21:13 »
Richard.
Please feel free to enlighten me (and the rest of us) as to what company will "probably" provide an installation disc that contains ALL variants of Vista (or any version of Windows come to that).
« Last Edit: 07 May 2010, 21:21:48 by KW »
Richard P
  • Wimborne, Dorset
    • Mercedes C350
« Reply #14 on: 07 May 2010, 21:31:57 »
My company, RP Computer Services, provided an OEM disk which contained all versions of Vista, it is the product key that determines what version of Vista the disk will install.
Richard.
