Author Topic: Fitting tyres to (small) wheels  (Read 2187 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
« on: 20 April 2010, 12:58:11 »
A bit off the normal tack, but.
Small trailer wheel (8-9" ?). Tubeless.  Wheel now tyreless too!
Is there a way I can pop it back on myself - not having tyre fitting aids to hand?
Re: Fitting tyres to (small) wheels
« Reply #1 on: 20 April 2010, 13:02:56 »
I'm sure I've done one myself, just carefully using a lever/screwdriver to ease it over the rim. A compressor would help to inflate it rapidly enough to seal the tyre against the rim till it seats properly.
« Reply #2 on: 20 April 2010, 13:08:28 »
There is another method that jeremy Clackson used on his trip to Iceland in his other series for the BBC.  Involved lighter fluid.   ::)
« Reply #3 on: 20 April 2010, 13:10:51 »
I remember that!  ;) You don't see them in ATS doing the same  ;D  ;D  ;D
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #4 on: 20 April 2010, 20:28:49 »
Yeah but haven't got a cylinder of butane gas with me! (well, I have but it's a new 15kg cylinder [bigger than the wheel] and I can't fly to Iceland at the mo).
Tyre is on the wheel.  Can't get a seal.  (No rude jokes pls.)  Tried the airline at the local (at the time) total garage, Pah no Oomph failed 'totally' - worth a 20p but it doesn't get any better.
- Did tell the mrs to stand-by for a big pop, what a let down!
Further thoughts ?  (for the tyre).
« Reply #5 on: 20 April 2010, 21:41:47 »
ATS/Kwick Fit on a quiet afternoon and ask nicely  ;)  ;)  ;)
r1
  • nottingham
« Reply #6 on: 20 April 2010, 21:44:13 »
take the valve out of the tyre and try the airline again
« Reply #7 on: 20 April 2010, 21:45:43 »
That's a good idea!  :y
« Reply #8 on: 20 April 2010, 21:51:51 »
Some airlines require you to press a button to give high volume/low pressure to inflate  "flat" tyres ..  ?
STMO999
« Reply #9 on: 20 April 2010, 21:52:46 »
Daz will blow it up for you, he's an old windbag.
JohnM
  • Newark on Trent
    • 2.5M Estate
Re: Fitting tyres to (small) wheels -sorted
« Reply #10 on: 22 April 2010, 20:20:02 »
Ah, tried a different airline.  Bit more omph, very nearly did it but still a leak and spayed me with the soapy water I'd got everywhere - I reckon I'd got a few PSI in it (no thump mind).  Turns out the valve had perished, it wasn't going anywhere.
New valve and its good to go !
PS Couldn't ask Daz - he's not talking to me :(
r1
  • nottingham
« Reply #11 on: 23 April 2010, 08:11:11 »
now you have it done fit some puncture safe in it
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #12 on: 23 April 2010, 18:55:51 »
Is that good for trailer wheels then?
I'd usually stay away from anything too gungy.
r1
  • nottingham
« Reply #13 on: 25 April 2010, 17:40:54 »
yes its great for all tyres both tube and tubeless
i fit it a lot to caravans as most of them dont have spares.
i quite ofton do the newark autojumble  as lots of bikers buy of me i sell diy kits or can come and install it for you
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #14 on: 12 May 2010, 18:52:55 »
Taa.
Sri a bit slow getting back!
Will consider "the gunge" !
- sorted for now but maybe worth doing ahead of 'next time'.
Verus the DIY kits, how much would a couple of trailer (baby) tyres cost?
