Author Topic: Any Bike Mechanics??  (Read 6823 times)
Peachy
Re: Any Bike Mechanics??
« Reply #15 on: 12 May 2010, 21:57:11 »
Cant be as bad as my mate who found some rust under his kawasaki gt 750`s fuel tank and used a wire bush to clean it up....Only for some small holes to open up and fuel start peeing out all over the place......I told him it might be wise to put his fag out... ::) ::) ::)
Sorry to dissapoint you Bertie but a lit fag won't ignite petrol  :y
I beg to differ!! I seen it happen, in Demolition Man, threw his fag on the floor and BOOOOOOOOOMMMMMMMM. Simon Pheonix (Wesley Snipes with the bleached hair) did it. If he can do it anyone can. ::) ::) ::) ::)
HAT COAT DOOR
  • Auckland
    • Mazda MPV
« Reply #16 on: 12 May 2010, 23:28:20 »
No something definatly went 'pop' under the tank, but the fuse did go as well.  I tried another fuse but it went straight away....
The coil crossed my mind, guess the tanks coming off........ ::) ::) ::)
On my Triumph Sprint ST the wiring loom that comes out from under the tank and up to the instruments is also connected to the handlebar switches and ignition switch. Every time I turn the bars the wiring loom flexes and rubs against a bracket that supports the radiator.
In my case the bracket wore through the insulation and took out the sidelights, tail light and instrument lights.
I'm guessing that the first wire to wear through on your wiring loom was the ignition circuit.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #17 on: 13 May 2010, 08:53:32 »
If that's a pre-2005 model then you also have a ground wire to the left bars that likes to break after 'n' turns of the steering and kills the starter and the horn!  Had that one yet? :D
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
« Reply #18 on: 13 May 2010, 11:41:25 »
Thanks for the answers, especially the advice re: fags and petrol.... :y
I've taken the tank off and had a good poke around hoping to see some molten plastic, but it all looks OK from a visual point of view :-/
The strange thing is that its now turning over fine and not blowing the fuse!  I need to check if there's a spark, but I don't have a plug socket that fits! I'll see if I can find an old sparkplug.....
Chris_H
  • E London/Essex UK
« Reply #19 on: 13 May 2010, 12:10:02 »
That's exactly the behaviour I would expect if it's a chafed wire.  You can 'fix' the fault for quite some time by that method - trouble is it then comes back when you're in the Scottish Highlands, at night, in the pouring rain!
If you have a supply of fuses, your best bet now might be to crank the bike and delicately wiggle the wires until the fuse blows then examine the (small) area you were moving.  You might want safety goggles too!
HolyCount
« Reply #20 on: 13 May 2010, 18:46:55 »
Nope... In fact, you can put a lit fag out in petrol :y
but it will certainly ignite the vapours smartarses :P
do smartarses give off vapours  :question
Mine does !!  ::)
« Reply #21 on: 14 May 2010, 00:21:36 »
Woo Hoo!! Managed to get it running this afternoon!! :y  But still have no idea why or what caused it!! :-/  Maybe I have a self fixing bike!! ;D
Think I'll take your advice Chris and will have a 'wiggle' and see if I can find the fault :y
Thanks for all the advice...... and comedy!! :D :) :P
