Individual female torx sockets
Started by Markie, 17 April 2007, 12:52:03
Markie
Does anyone know if Halfords or similar sell individual torx sockets. I know they sell individual sockets  :-/
Sat at work here - after a trip to vx before i started to get water pump and thermostat bolts - and i have just realised i lost my e10 at the weekend  >:(
Machine mart want me to buy a whole set - not a chance Mr Mart ! and theres no time to get an individual one from ebay as i am off from Thursday to get it completed.
I cant use a spanner or similar as i need to torque the bolts....
Yes they do....not cheap though....
Craig_R
#2
I got my E10 Torx female socket for 3 pounds from a local garage supplier i think they are called Allparts Automotive
I think the female socket was draper or something
Craig
Mod's
[To be Fitted]Reverse Sensors
Markie
QuoteYes they do....not cheap though....
nothing ever is in there but needs must  :( cheaper than buying a whole new set from 'mart  :-/
hotel21
hotel21
Markie
Big thanks to Hotel21 here folks.....the forum strikes again  :)
Broocie has just solved all my short term issues by taking the time out to wrap, address go out to the post office and post first class the socket i so desire.
Ii owe you one Broocie  :y
Good man Broccie :y
Markie, sockets are £3.50 each from halfrauds... they do individual torx...
Markie
QuoteGood man Broccie :y
had wife check after M DTM said they did them albeit expensive - local one didnt have any - but it is small  :-/ Thanks for the heads up - will try a bigger branch  :y
sounds2k
dunno if it's the same elsewhere but my local Halfrauds sell individual torx sockets ... well some ... sadly not including the one I have missing!! (E11) ... they do E8, 10, 12 etc. though  :'()
jonny2112
My set only goes up to E18 and I need an E20 for the crank! Halfords don't do any larger than 16 iirc but have sourced a single socket (rather than another set) at a local factors. Going for it tomoorrow, but it is expensive at £4.50, although it is quite large and probably not too common.
Markjay
#11
You should always use the right tools for the job, but if you do get into a tight spot then I found that you can use standard 12-point sockets on Torx bolts.
I would only do that if the bolt is reasonably small and the torque is not too high, and ensure there is a good fit.
This is how I tightened all the 8NM bolts on the cam covers and throttle body – due to bad planning and lack of foresight, my Torx socket set is 3/8" drive while the 5-25NM torque wrench is 1/4" drive...
Now go on, cast the first stone...  ;D
Alas, no more Omegas....
Markjay
..and Well Done to Hotel21 for his help!  :y
QuoteYou should always use the right tools for the job, but if you do get into a tight spot then I found that you can use standard 12-point sockets on Torx bolts.
Wouldn't fancy turning crank over without the proper torx!
Markjay
Ah, that's where the locking pliers come in handy!  ;D
