Author Topic: Caravanning in an old car.  (Read 1190 times)
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
« on: 28 May 2010, 19:07:59 »
 The Rover 2000 is positive earth (1970 J reg.) Towbar fitted but can i just plug the van in & go? I don't think so much as TB would welcome the sight of burning Elldis BBQ. I've told to swap the pos & neg over on the tow hitch depending on which car i tow with & disconnect the leisure battery while towing. Both cars only run a single system so it's only for exterior lights whilst on the move.
   Any ideas please? Guy. :-/
Re: Caravanning in an old car.
« Reply #1 on: 28 May 2010, 19:16:50 »
 :o :o :o What have I missed?? ::) ::) What happened to the Consul ::) ::)
Mind I prefer the P6 Rover anyway :D :D
I think Guy you would need to change the polarity of the car or change this on the caravan by altering the wiring, I think..... :y
Martin_1962
« Reply #2 on: 28 May 2010, 19:54:19 »
It is missing 1500
« Reply #3 on: 28 May 2010, 20:12:21 »
I wouldn't have thought you'd have a problem with just the primary electrics connected. It should only be bulbs attached and they don't mind which way the electrons flow. :y
« Reply #4 on: 28 May 2010, 20:37:32 »
....is it the TC ....Amigo?.
Amigo
« Reply #5 on: 28 May 2010, 20:57:56 »
Yes it is a TC. Just bought 2 original fram air filters for £8. 12 months t&t 83k, £700. Slight knock on front suspension & a noisy thrust bearing. Used it for the last 2 weeks with no bother. Consul sold for £2500. 8-)
Omegatoy
  • UK
« Reply #6 on: 28 May 2010, 22:15:20 »
take it that it has a dynamo then? if so simply change the car to neg earth very easy on dynamo cars!!
mantahatch
« Reply #7 on: 28 May 2010, 22:50:59 »
Yes I would second that.  :y
Just a thought, if you just plugged the caravan in to the car, if caravan used the chassis for any earth points could there be a problem through the tow ball connection ? Getting way past my bedtime, so I may be talking rubbish.
« Reply #8 on: 28 May 2010, 23:25:18 »
....  so I may be talking rubbish.
I couldn't possibly comment!  ::)  ::)
but ........... yes!  ;D  ;D  ;D  ;D
No earth connection via caravan chassis  :y
« Reply #9 on: 28 May 2010, 23:25:27 »
I was thinking that, but if it is only lights then it does not matter which way the electric flows, the problem comes if there is any equipment, particularly a radio in the caravan that would be polarity sensitive...... :)
« Reply #10 on: 29 May 2010, 00:12:33 »
Correct. it really doesn't matter to the caravan if the common return for the light is connected to the chassis as this will be connected to the car chassis too. Whether it's positive or negative is not an issue.
mantahatch
« Reply #11 on: 29 May 2010, 08:18:06 »
 ;D ;D ;D
sexydaz
« Reply #12 on: 29 May 2010, 08:27:01 »
enough chat lets have some piccys :-*
