Re: LPG Project - Progress Update 1
Started by TheBoy, 19 April 2007, 21:29:00
No, the main fault is it needs a wash and vac ;D
So when you've finished the bathroom (or sent her away for a weekend ;D), fancy showing me how to do the check strap repair.  And fix my sump bolt. And.....
Has yours got a broken check strap then?
I take the doors off to do the check strap.....much easier.....
QuoteHas yours got a broken check strap then?
Tractor has strap no longer attached at door end.
You've just made a scary job sound even scarier  :-[
Door removals easy....even managed it on my own!
QuoteDoor removals easy....even managed it on my own!
I hope you did a Maintenece Guide...  ...I'm gonna need it!
Bo Bo
Well I didn't manage it on my own, but it is easy...
Opps, completely hijacked that thread, so split off to new thread...
I notice on my door strap on the driver's side the bracket on the pillar is starting to come away from the pillar. Just a few cracks around the edge but it's clearly moved a little. Still secure at the moment but I'd be interested in how a repair can best be effected.
sounds2k
well a basic how-2 guide which gives the part numbers for the repair plates can be found here ... although if it's really bad I guess you'd probably need to strip the door completely and weld the repair plates to what's left of the door ...
QuoteI notice on my door strap on the driver's side the bracket on the pillar is starting to come away from the pillar. Just a few cracks around the edge but it's clearly moved a little. Still secure at the moment but I'd be interested in how a repair can best be effected.
I drill holes in the plate and plug weld it......15 mintue job....if you have a welder!
QuoteI drill holes in the plate and plug weld it......15 mintue job....if you have a welder!
I thought there'd be a caveat like that appended to the answer  ;)
Of course even if I had a welder I'd be sure to make a complete horlicks of it. Have had the desire to learn to weld in the back of my mind for a few years now, but I'm certain that this is not the ideal starter project.
I'll keep an eye on it and make a mental not to treat it gently for now.
Cheers,
Next time there is a meet any where and you are attending, I'll sort it out...
