Project Elite - HUGE MOT Failure :(
Started by JamesV6CDX, 19 April 2007, 21:04:14
[size=24]Just Kidding !!   ;D ;D ;D ;D ;D[/size]
She flew through, first time, with a couple of poxy advisories....
Go for GM exhaust, unless your old CDX one is useable...
It's only the backbox... you can see all the cotton wool blocking the exit! The tester put a rubber glove on exhaust to watch it blow up!
Still stick to GM though ;)
Bo Bo
 :-? Why is a possible auto gearbox fault an advisory?   :-/
Quote:-? Why is a possible auto gearbox fault an advisory?   :-/
That connector came loose.. putting it into limp mode.... meaning it pulled away about as fast as a snail!
The testers take the piss now with the advisories......
I got one on the MV6 due to the plastic sideskirts...
STMO123
Well done James. Your next project?
jonny2112
Timbuk
QuoteI got one on the MV6 due to the plastic sideskirts...
Join the club :-/
Martin_1962
Excellent news!
So is the gearbox problem just down to the broken pin on the connector?
If you need to source  a new pin to repair it you might want to have a look at http://www.vehicle-wiring-products.co.uk/. They have an assortment of different pins for various automotive connectors. You could extract the old pin, solder a new one onto the wire and then poke it back into the connector.
Failing that I guess you could get a complete connector from a breaker and splice the wires together in the loom. If you could extract the pin you could do this just for the broken pin, thinking about it.
