Another new Guide
Started by x25xe, 17 April 2007, 23:12:05
x25xe
I have just posted another maintenance guide - this time dealing with changing a track rod end.  It can be found here - http://www.omegaowners.com/forum/YaBB.pl?num=1176846802
Hope it is of use to somebody.
sounds2k
#1
a handy guide, changing the track rod isn't too difficult to do - but it's always really handy to have a walkthrough with pictures for the first time you do the job ...
however, I have a few observations / suggestions to make:
  • I used an 18mm socket and ratchet on my splitter, found the ratchet spanner kept dropping off otherwise ...
  • when trying to refit the new track rod, if the bolt spins round (yep - mine did the same thing) I tapped the back of the track rod end with a rubber mallet, this engages the end with the spring in the arm that locks the pin in place (if you follow what I mean) - found that much easier to do (didn't think of the breaker bar option TBH)
  • torque settings are in haynes manual (or at least the one I have) - see the sub-section labelled "steering" in the torque wrench settings at the start of chapter 10 (page 10.3), half-way down), the missing ones are:
    outer tie rods to centre tie rod & tie-rod balljoint nut - both 60Nm / 44 lbf ft
    outer tie rod clamp bolt = 15Nm / 11 lbf ft
    they're also in TIS and give the same values which is good  :)
hope that makes it even easier  :y
Markie
QuoteI have just posted another maintenance guide - this time dealing with changing a track rod end.  It can be found here - http://www.omegaowners.com/forum/YaBB.pl?num=1176846802
quality guide and pictures  :y
Markjay
Very professional... and a worthy addition to our Maintenance Guide section!  :y
Alas, no more Omegas....
Auto Addict
I like red cars
x25xe
Quotea handy guide, changing the track rod isn't too difficult to do - but it's always really handy to have a walkthrough with pictures for the first time you do the job ...
Cheers for the above sounds2k - I did not think of the rubber mallet option! - Yes, I know what you mean about the spring locking in place.  Will adjust the torque settings in the guide a little later on.  Thanks for those, I must have missed them in the guide.  Nice to note that Haynes (which I have) and TIS (which I do not :() agree!
Thanks everyone else for your comments.
One additional piece of advice......prep the assembly first by removing both track rod ends and cover all the threads in grease...lots of it....this will make future adjustment dead easy and means there wont be some heavy handed guy with mole grips trshing your track rod ends  whne trying to adjust them....
As always, when fitted to the car, wipe some grease around any exposed threads...
Can I sudgest that the torque values are in Nm......we did go metric in the seventies .....  ;)
x25xe
Two good points Mark, I meant to Copper Ease the threads for the exact reason you said.  Forgot to do it when doing the job and, worse still, forgot again when writing the guide.  Will add this.  Sorry about the torque values - it is just that I use the imperial measurements.  I will add the metric ones in as well.
Thanks for your input!
x25xe
OK,
I want to add in the torque values, add the Nm values as suggested.  I also want to make the point about Copper Easing the threads as suggested by Mark.
Just been into the guide in the hope of editing it, but find I can't.  All I can do is delete it.  So, how do I edit the guide please?
Auto Addict
I can do it for you, just post the nm values here, and I'll add them.
I like red cars
