Author Topic: Another SQL query needed...  (Read 4447 times)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: Another SQL query needed...
« Reply #15 on: 03 June 2010, 22:20:15 »
Here endeth the sequel sequel?  ;)
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
« Reply #16 on: 03 June 2010, 22:36:38 »
yep..ended. if I wrote the actual code would be long enough but brain not performing well at the moment :P :-[
also there are other alternative solutions but too much alcohol in blood ;D
« Reply #17 on: 03 June 2010, 22:41:08 »
Cheers cem :y - I used your SQL, worked out how to manipulate into my flexgrid, seems to work a treat :y
Thank you very much :y
Expect a harder query next time (probably over the weekend) ;D ;D
« Reply #18 on: 03 June 2010, 22:43:37 »
your are nearly passing my knowledge limits I hope I can solve next time :-[
Good night :y :y
« Last Edit: 03 June 2010, 22:45:18 by cem_devecioglu »
« Reply #19 on: 03 June 2010, 23:00:06 »
Good night :y :y
Oh, its going to be a pig of a query.  If you can even think you can get the data out with a single query, then you are a better man than me ;D
I need to look at the tables and relationships again before I can give you a clue ;D
« Reply #20 on: 04 June 2010, 09:43:41 »
Good night :y :y
I hope I can help..sometimes I use temporary tables to hold the calculated tables if I'm lazy to use  matrix.. ;D
« Reply #21 on: 04 June 2010, 15:37:52 »
Cem, that query is now in production use in my Brother's shop :y :y
Ready for the next one? ;D
« Reply #22 on: 04 June 2010, 16:05:12 »
yep.. :y
« Reply #23 on: 04 June 2010, 16:24:42 »
I need a query that will get the total stock value (actual cost, and current retail).
Current retail is easy: = Qty in stock * current retail price.
Actual cost is more tricky, as it needs to ascertain how many in stock, then step back through invoices to work out actual cost paid for those items in stock - ie, last invoice may say £100 cost, previous invoice may say £90. So if there are 3 in stock, 2 were on last invoice, and 2 were on previous invoice, it needs to work out 2 x £100 + 1 x £90. If that makes sense?
Tables:
Products
ProductID - unique key
Description - description of product
RetailPrice - current retail price
CostPrice - current cost price (but not used in this query?)
StockLevel
StockLevelID - unique key
BranchID - link to branches (query needs to simply work for all branches added together)
UnitsInStock - integer for how many in stock at branchid
Invoices:
InvoiceID - unique key
ProductID - link to products
Quantity - integer for number of this item recieved
CostPrice - price for each item on this invoice
Does that make sense?
« Reply #24 on: 04 June 2010, 16:26:28 »
Would it help if I sent you an blank Access DB to show the DB layout?
« Reply #25 on: 04 June 2010, 16:26:57 »
Tables:
Products
StockLevel
Invoices:
yep.. will try now..  :y
« Reply #26 on: 04 June 2010, 16:37:38 »
I see one problem, there must be product ID field
in stocklevel table or I cant sum up .. probably you forgot to write :-/
« Reply #27 on: 04 June 2010, 16:39:41 »
nope not necessary.. only field and table names are adequate..
« Last Edit: 04 June 2010, 16:39:55 by cem_devecioglu »
« Reply #28 on: 04 June 2010, 16:49:51 »
Yeah, my bad, there is a ProductID in table StockLevel...
« Reply #29 on: 04 June 2010, 16:52:55 »
now the simple one currentretail calculation
assuming you dont want calculate per branch instead global otherwise we must use Branchid in group by
select p.ppid,p.Description,p.Retailprice,curretail=p.Retailprice * s.cumstockforprod from
(select ppid=ProductID,Description,RetailPrice,CostPrice from Products) as p,
(select spid=ProductID,cumstockforprod=sum(UnitsInstock) from StockLevel group by ProductID) as s
on p.ppid=s.spid
and now solving the other..
« Last Edit: 04 June 2010, 16:54:56 by cem_devecioglu »
Pages: 1 [2] 3 4  All   Go Up
