Author Topic: Another SQL query needed...  (Read 4445 times)
Re: Another SQL query needed...
« Reply #45 on: 05 June 2010, 12:19:29 »
dim adoconnection1 As New ADODB.Connection
dim adoconnection2 As New ADODB.Connection
dim adoconnection3 As New ADODB.Connection
dim rsl As New ADODB.Recordset
dim rs2 As New ADODB.Recordset
dim rs3 As New ADODB.Recordset
' here other variables used must be declared also
cp1 = "Provider=sqloledb;uid=sa;pwd=password;server=servername;database=dbname ;"
    Set adoconnection1 = New ADODB.Connection
    adoconnection1.CommandTimeout = 2000
    adoconnection1.ConnectionTimeout = 10
    adoconnection1.Open cp1
    Set adoconnection2 = New ADODB.Connection
    adoconnection2.CommandTimeout = 2000
    adoconnection2.ConnectionTimeout = 10
    adoconnection2.Open cp1
    Set adoconnection3 = New ADODB.Connection
    adoconnection3.CommandTimeout = 2000
    adoconnection3.ConnectionTimeout = 10
    adoconnection3.Open cp1
gridrow=0
txt1="select ProductID,Description,RetailPrice,CostPrice from Products order by ProductID" 'read every product id
Set rs1 = New ADODB.Recordset
rs1.Open txt1, adoconnection1
While rs1.EOF = False
  txt2="select cumstockforprod=sum(UnitsInStock) from StockLevel where ProductID=" & rs1!ProductID
  Set rs2 = New ADODB.Recordset
  rs2.Open txt2, adoconnection2
  cumstockforprod=rs2!cumstockforprod ' get cumulative stock for that product
  suminvoicecount=0
  sumactualcost=0.0
txt3="select Invm.imid,Invm.Invoicedate,Invd.ProductID,Invd.InvoiceDetailID,Invd.CostPrice,Invd.Quantity from "
txt3=txt3 & " (select imid=InvoiceID,InvoiceDate from Invoice) as Invm, "
txt3=txt3 & " (select idid=InvoiceID,ProductID,InvoiceDetailID,CostPrice,Quantity from InvoiceDetails) as Invd "
txt3=txt3 & " where Invm.imid=Invd.idid and Invd.ProductID=" & rs1!ProductID & " order by Invm.InvoiceDate,Invd.InvoiceDetailID desc "
'if Invoicedate includes hour, minute, second details InvoicedetailID can be omitted but "desc" is the critical part as you already know..
  Set rs3 = New ADODB.Recordset
  rs3.Open txt3, adoconnection3
  while rs3.eof and suminvoicecount<cumstockforprod
    if suminvoicecount+rs3!Quantity <=cumstockforprod then
       suminvoicecount=suminvoicecount + rs3!Quantity
       sumactualcost=sumactualcost + rs3!quantity*rs3!CostPrice
    else
       suminvoicecount=suminvoicecount+(cumstockforprod-suminvoicecount) '
       sumactualcost=sumactualcost + (cumstockforprod-suminvoicecount)*rs3!CostPrice
    end if
    rs3.movenext
  Wend
   '  now write to grid or print
    gridrow=gridrow+1  '
    grid.rows=gridrow+1
   grid(gridrow,1).text=rs1!Description
   grid(gridrow,2).text=sumactualcost
 rs1.MoveNext
Wend
and I must note as I have no data handy I cant test it..
« Last Edit: 05 June 2010, 12:19:57 by cem_devecioglu »
« Reply #46 on: 05 June 2010, 12:21:45 »
Jaime , in sql 2005 this transposition or pivoting is a bit easier..  :y
http://geekswithblogs.net/lorint/archive/2006/08/04/87166.aspx
Sadly, this also has to work in Jet/Access, so unlikely I can use SQL2K5 specific functions :(
I'll write a pivoting code with the supplied fields as soon as possible but probably tomorrow.. :y
« Reply #47 on: 05 June 2010, 22:23:14 »
No hurry, can't code this in for a few days anyway....
« Reply #48 on: 05 June 2010, 22:52:03 »
for pivoting I'll prepare the tables and some data
cant write it without testing..
« Reply #49 on: 06 June 2010, 22:35:38 »
code for pivoting
Dim adoc1 As New ADODB.Connection
Dim rs As New ADODB.Recordset
Private Sub Command1_Click()
Dim cp1 As String
Dim txt As String
Dim countx As Integer
Dim county As Long
Dim xcord As Integer
Dim ycord As Long
Dim locidmatrix(500) As Integer
Dim prodidmatrix(10000) As Long  ' space is only limited to virtual ram >=array size * 4bytes
Dim locprodmatrix(500, 10000) As Long
' change with necessary access connection string..
cp1 = "Provider=sqloledb;uid=sa;pwd=yasak;server=IULIA-PC;database=testdb;"
    Set adoc1 = New ADODB.Connection
    adoc1.CommandTimeout = 2000
    adoc1.ConnectionTimeout = 10
    adoc1.Open cp1
grid1.ColWidth(0) = 2000 ' product names column with in twips scale
'now prepare x axis for grid or table
txt = "select slid,locationDescription from " ' check the double quotes there must be one extra space on the right side
txt = txt & " (select LocationID,LocationDescription from Location) as loc, "
txt = txt & " (select distinct s.slid from "
txt = txt & " (select pid=ProductID,ProductDescription from Products) as p left outer join "
txt = txt & " (select spid=ProductID,slid=LocationID,NumberInLocation from Stock) as s "
txt = txt & " on p.pid=s.spid) as DisLocID "
txt = txt & " where loc.LocationID=DisLocID.slid order by LocationDescription"
countx = 0 ' x coordinate items count initialized
grid1.Cols = 1 ' arrange grid columns accordingly
Set rs = New ADODB.Recordset
rs.Open txt, adoc1
While rs.EOF = False
  countx = countx + 1
  grid1.Cols = grid1.Cols + 1
  grid1.TextMatrix(0, countx) = Trim(rs!LocationDescription)
  locidmatrix(countx) = rs!slid 'id s will be necessary as we use a different order then id
  rs.MoveNext
Wend
'now prepare y axis for grid or table
txt = "select ProductID,ProductDescription from "
txt = txt & " (select ProductID,ProductDescription from Products) as p, "
txt = txt & " (select distinct ProdID=ProductID from Stock) as s "
txt = txt & " where p.ProductID=s.ProdID order by ProductDescription "
county = 0 ' y coordinate items count initialized
grid1.Rows = 1 ' arrange grid rows accordingly
rs.Open txt, adoc1
  county = county + 1
  grid1.Rows = grid1.Rows + 1
  grid1.TextMatrix(county, 0) = Trim(rs!ProductDescription)
  prodidmatrix(county) = rs!ProductID
  rs.MoveNext
Wend
'prepare actual data table
txt = "select p.pid,s.slid,s.NumberInlocation from "
txt = txt & "(select pid=ProductID,ProductDescription from Products) as p left outer join "
txt = txt & "(select spid=ProductID,slid=LocationID,NumberInLocation from Stock) as s "
txt = txt & " on p.pid=s.spid order by p.pid,s.slid"
rs.Open txt, adoc1
  locprodmatrix(rs!slid, rs!pid) = rs!NumberInlocation  ' location and product ids are used as indices
  rs.MoveNext
Wend
' now pivot the table with the help of matrix and loop
For ycord = 1 To county
     For xcord = 1 To countx
         grid1.TextMatrix(ycord, xcord) = locprodmatrix(locidmatrix(xcord), prodidmatrix(ycord))
     Next xcord
Next ycord
End Sub
« Last Edit: 07 June 2010, 13:38:04 by cem_devecioglu »
« Reply #50 on: 06 June 2010, 22:37:35 »
and here is how the actual grid looks with some test data
if you need I can supply also a code that you can transfer the pivoted table to excel also which will be helpful for printing purposes..
« Last Edit: 06 June 2010, 22:42:48 by cem_devecioglu »
Martin_1962
« Reply #51 on: 07 June 2010, 16:47:17 »
That is something I could knock up using ISAM access and BBrowser in VO in minutes!
I think I'll pass on SQL for now!!!!
« Reply #52 on: 07 June 2010, 17:05:40 »
this is for access not for sqlserver Martin..
and by the way chronometer already started :D ;D
« Last Edit: 07 June 2010, 17:06:45 by cem_devecioglu »
Pages: 1 2 3 [4]  All   Go Up
