I'm Worried - VERY worried
Started by Markie, 20 April 2007, 19:16:58
Markie
About the veccy cambelt :-/
Should the adjuster/ idler be able to move on its on by hand with belt in place.
Cams and tensioner dont.....
Also cams DONT seem to me to line up if it was cranked round tdc.....
Theres no leaks on tensioner and no play in belt.... :-/
STMO123
Wait for Marks DTM on this one Markie :o
Well for starters....rotate the crank another 360deg ......the cams are 180 deg out....
When you say you can move the tensioner....can you feel some spring tension...
Also.....what is the number/letters cast into the bottom of one of the webs on that tensioner/idler back plate....
Ronald_McBurger
Yes, agreed. Cams are 180 degrees out.
Markie
QuoteWell for starters....rotate the crank another 360deg ......the cams are 180 deg out....
.....i've only just taken the cover off - toucnd nothing.... :-/ the top idler spins round by finger without the belt moving but the belt is taught...
this looks bad doesnt it..
Read that info off the backplate....it should be 01....but it might be EB.....
Another question....have you turned the crank at all.....if so, did you turn it anticlockwise at all....
Markie
QuoteAnother question....have you turned the crank at all.....if so, did you turn it anticlockwise at all....
no crank has not been turned - i know its clockwise only too....
Whats stamped on the tensioner backplate then.....
Markie
#10
QuoteWhats stamped on the tensioner backplate then.....
cam sprockets/ backplates the part number.......... 90573286     then 0037219 at a seperate part for all 4 cams.
Top idler 337185 a    then      france 90573616
need anything else?
edit
going to check that back plate itself....
Markie
no other writing that i can see......
from this picture its ONLY the top idler that rotates on its own - nothng else does......
Yes but, something looks odd with the top idler position.....if you look at the silver cast backing plate that the idler adn tensioner are mounted on.....in between the two stamped inside one of the webs is two digits which tell you what type of setup is fitted.....its these two digits I need...
The top idler might be rotating on its own simply because of the cam positions.....and the varying load on the belt as they go over centre...
I am asking this question by the way as I suspect it has the wrong tensioner assembly fitted, it looks like the early one (EB) and hence why the the top idler is not between the cams....
On closer inspection, the timings dont look massively out of time....think cranks closer to needing  440 ish deg turn...
