Author Topic: Do Building Control know anything!  (Read 4316 times)
« on: 07 July 2010, 11:40:30 »
I have an on going arguement with Market Harborough building control department who, from what I have researched, dont know the regs!
The scenario is an extension where the rainwater from the roof is being discharged into a water butt with no further provision to manage drainage!
My understanding of Part H3 (Drainage and waste disposal - Rainwater drainage) of the building regulations is that the following options must be followed in priority order:
1) Discharge into a soak away or infiltration system.
2) Discharge to a water course.
3) Discharge to a sewer.
The solution in question has none of these and hence once the water butt is full, it will over flow and cause damp issues with the construction which it is adjacent to.
Clearly this is not an acceptable solution and one the builder should be addressing as per the architects plans (which describes discharge into a sewer).
Assuming the standard figure of 0.014 litres/second/m2 of rainfall intensity (taken from H3) and an approximate roof footprint of 12m2 (estimate) we could get 10 litres per minute of water discharged. This would fill a 210 litre water butt in 21 minutes and hence why the building regulations do not support such a rain water control solution.
So if anybody know about such things then any feedback would be appreciated!
Re: Do Building Control know anything!
« Reply #1 on: 07 July 2010, 11:44:24 »
I am assuming this affects you, personally, if it was me affected, would pop over with my Makita drill and 'add' some drainage to the side of the water butt  :D - But on their side  ;D
« Last Edit: 07 July 2010, 11:45:11 by tunnie »
« Reply #2 on: 07 July 2010, 11:47:57 »
No need, they are leaving the tap permanently open!
But, I am concerned that the building control officer might sign this extension off!
« Reply #3 on: 07 July 2010, 11:52:21 »
Then whats the point of it?  :-/ - Guessings its cheaper than having drains routed to the correct place?
Grandpa tunnie has waterbutt at his extension, the over-flow is a simple bit of hose than runs to the drain at the back of the house
« Reply #4 on: 07 July 2010, 11:58:56 »
That's OK until the tap blocks up with crud, which it will in short order as it's skimming debris off the top of the water.
It's clearly an unacceptable arrangement, and I can't imagine how it could be seen to meet building regs but there seems to be an increasing tendency to turn a blind eye to rubbish that doesn't conform in this country. >:(
« Reply #5 on: 07 July 2010, 12:24:41 »
Its not ok as the water is discharging adjacent to the foundations and will cause damp issues (hence why the regs say a soak away must be sited 5m from a foundation and a road).  :y
« Reply #6 on: 07 July 2010, 12:30:08 »
Didn't mean to imply it was acceptable, of course. It will soon fill up and start discharging over the back of the butt and down the wall, though. ;D
Nickbat
« Reply #7 on: 07 July 2010, 12:36:27 »
Mark, if it could affect your property all you need to do is get in touch with the legal department at your house insurers. A letter from them holding your neighbour liable, blah, blah will be enough to make them rethink their design, I feel sure.  :y
« Reply #8 on: 07 July 2010, 12:41:38 »
Already started that process thanks Nickbat.
My big concern is that building control might actualy sign this work off!
des.allen
  • Preston lancs
  • 2000 2.5 v6 elite nearly LPG
« Reply #9 on: 07 July 2010, 12:45:08 »
Mark, This is what should be followed as it was agreed when planning permission was granted. Any deviation from this would mean having to re apply for planning permission. HTH :y
« Reply #10 on: 07 July 2010, 13:13:31 »
Sadly thats not the case.
Planning are not interested, its only present on the plans because they used the same plans to support a full plans submission to building control.
Its building control that have to enforce this bit.  :y
Nickbat
« Reply #11 on: 07 July 2010, 13:21:52 »
« Reply #12 on: 07 July 2010, 13:24:48 »
At the end of the day, there is always the Ombudsman:
http://www.lgo.org.uk/publications/fact-sheets/complaints-about-building-control/
Thanks Nickbat, added to favourites
markspark
  • Bolton
« Reply #13 on: 07 July 2010, 13:38:08 »
i would contact the lbc and find out who there inspector is shoe him photos and he should see your point of view damp can cause a lot of problems  and the spors from it can make you very ill
the water butt is good idea but only for garden shed ecw
« Reply #14 on: 07 July 2010, 13:42:24 »
Would have thought it was obvious that all rainwater should be drained efficiently, was the extension built to the rules in the 1st place or did the owner cut corners one the building was up.
Either way, common sence would have told me that if I instelled a water butt it will fill up one day, I would have then fitted an overflow system back into the drain pipe/system (opps, you cant in this case - as that is the reason for your complaint  ::) )
