Author Topic: 650 Bandit  (Read 2160 times)
650 Bandit
« on: 08 July 2010, 23:33:55 »
My lads's mate brought his Bandit round this evening to use my garage & tools to replace his drive chain & sprockets (I didn't think there was much wrong with the old bits .... but still  :-/)
He couldn't remove the main drive sprocket .... & neither could I. We roughly assembled the chain again so we could hold it with the chain & a back wheel locked up with the back brake. There was a 4 lug 'thing' bolted to the drive shaft .... there was a sensor of some kind 'looking' at it, but the 32mm nut holding the sprocket didn't want to budge with either my windy gun or 3' breaker bar.
Any one know if we missed anything?
  • Online Online
Re: 650 Bandit
« Reply #1 on: 08 July 2010, 23:39:55 »
Are you turning the nut the right way, some applications have left hand threads so it keeps them tight when rotating.
Re: 650 Bandit
« Reply #2 on: 08 July 2010, 23:43:39 »
Yes, we checked it was a right hand thread, there was just enough thread showing to check.  :y Even if we were going the wrong way, you can normally get a little movement. This was solid. :-?
Re: 650 Bandit
« Reply #3 on: 09 July 2010, 00:22:14 »
http://www.fixya.com/motorcycles/t2017860-remove_front_sprocket_suzuki_gsfs
Don't know if this will help, link to manuals.
Sensor will be for speedo.
Usually left hand thread with a tabbed locking washer holding it on to stop it coming loose, if no tab washer it may have been over applied with lock tight to keep it on,  no experience with that exact model though. :-/
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: 650 Bandit
« Reply #4 on: 09 July 2010, 01:02:47 »
Your weetabix this morning? ;D ;D
« Last Edit: 09 July 2010, 01:03:35 by CaptainZok »
TuBy's new whipping boy.
bertiecbx550
Re: 650 Bandit
« Reply #5 on: 09 July 2010, 01:30:20 »
I`ve just had a look on google and bing and come up only instructions on how to remove the sprocket on a v-strom...Hve you seen a locking washer behind the main nut and have flattened it so as to allow the main nut to spin? if not this could well be the problem so i would have look and then do the above and this should allow the nut to spin....I used to use an old flat screwdriver and gently prise it flat and then undo the nut on my old Gsx 400f....Hope this helps....Also you may have to heat the sprocket up to allow the thread locker to break...
« Last Edit: 09 July 2010, 01:33:58 by bertiecbx550 »
Re: 650 Bandit
« Reply #6 on: 09 July 2010, 05:53:58 »
thanks for the suggestions lads, but definitely no tab washer - no problems fitting the socket over the nut, there must be a bottle of Loctite on there. We/he gave up & left the original drive sprocket on, there wasn't much wear, but it was a shame having to keep the old drive sprocket when a new chain and final drive spocket on the wheel was fitted.  :(
Re: 650 Bandit
« Reply #7 on: 09 July 2010, 07:38:35 »
Of course  :y
....Usually left hand thread with  ....
There was just enoughthread showing to see it's right hand. Sprocket on near side would say that normal right hand thread would self tighten  :y
Re: 650 Bandit
« Reply #8 on: 09 July 2010, 07:48:01 »
Risky that, the sprocket will have worn to the old chain.....it wont show much but it will have.
And a worn sprocket is much more likely to throw the chain.
Try warming the nut up a bit (it does not need to be much) to soften any thread lock that might have been used.
Re: 650 Bandit
« Reply #9 on: 09 July 2010, 08:04:03 »
should have got a bike with shaft drive  ::)
Re: 650 Bandit
« Reply #10 on: 09 July 2010, 09:24:08 »
Completely agree, but time was also against us too. I'll suggest he brings it back & we can have another go. I just didn't want to break anything by forcing it.  :-?
Re: 650 Bandit
« Reply #11 on: 09 July 2010, 09:24:53 »
but at least my car has a full quota of cylinders  ;)  ;)  ;)  ;)  :y
Re: 650 Bandit
« Reply #12 on: 09 July 2010, 09:43:25 »
Ask PaulW he has a 1200 Bandit ;)
Re: 650 Bandit
« Reply #13 on: 09 July 2010, 09:53:29 »
Just you wait till i get a V8  :P
No sod it, i'll get an A8 W12, then you'll only have 1/2 an engine  :D
Re: 650 Bandit
« Reply #14 on: 09 July 2010, 10:17:42 »
With all the added weight and associated instability it results in when airborn......
