Vx part number please!
Started by RossPhim, 26 April 2007, 19:12:42
RossPhim
Can one of you fine chaps give me the vx part number for the rear disc brake pads, and if possible the retail price (no trade car here   :'( ).
The car is 1999 2.5V6 Mini facelift Elite.
Many thanks!  :y  :y
Ross
9192126 axle set of rear brake pads £18.75+vat
RossPhim
Cheers, Mark!
Thats a job for tomorrow evening sort out.
May also be worth investing in the little spring clips - I find they are often broken at the rivet...
Markie
QuoteCan one of you fine chaps give me the vx part number for the rear disc brake pads, and if possible the retail price (no trade car here   :'( ).
Many thanks!  :y  :y
Ross
If only you were neared id TC them for you....guess the savings would go in postage costs  :-/
RossPhim
Many thanks!  :y  :y
Ross
Cheers Markie, but I need to get them replaced quick!
A nice grinding noise started from the rear n/s on way home tonight.
Many thanks!  :y  :y
Ross
tut tut, who doesn't check them often enough  ;D
Markjay
QuoteMay also be worth investing in the little spring clips - I find they are often broken at the rivet...
...'little spring clips'...? where? what...?  :o
Alas, no more Omegas....
look it up on epc - 90509233 (for prefacelift, facelift is different part)...
RossPhim
Many thanks!  :y  :y
Ross
All was well back in Feb when she was made ready for the MOT.   :-/
You never know I may well find a bit of grit trapped in the, but at that price there's no reason to not change them. I've had the barge of 2 years now anyway.
If it wasn't for having to take off the blinkin' wheel it would almost as easy a job as the door check strap nylon bush replacement.  ;D  ;D
Many thanks!  :y  :y
Ross
LOL, I did the same on the MV6 a year or so ago, no real idea why they suddenly wore quickly.  Fortunately I caught mine very quickly.  Everything was free, so wasn't sticky pistons etc....
Markjay
#11
Quote...for prefacelift, facelift is different part...
Phew... you got me worried there for a minute... just fitted mine a couple of weeks ago and no clip...
RossPhim
Pads replaced, but had to go to factors as local stealers didn't have them in stock!
Didn't really want to wait till next week and having now seen the state of the old ones I glad I didn't wait any longer.
Questions
1.  Who wants to see the sad state of the old ones.  :-[  :-[
2.  Why do Vx give us such a tiny little, piece of sh1te, jack to lift nearly 2 tonnes of car.  >:(  >:(
Having just use the jack I don't think I would fancy my chances much changing a wheel at the side of the road.
DaveL
QuotePads replaced, but had to go to factors as local stealers didn't have them in stock!
Questions
1.  Who wants to see the sad state of the old ones.  :-[  :-[2.  Why do Vx give us such a tiny little, piece of sh1te, jack to lift nearly 2 tonnes of car.  >:(  >:(
[/color]
They are not the only ones. Invest in a trolley jack and set of Axel stands. The supplied jack is only for emergencies and not for when you are servicing parts of the car. Have seen too many come off this piece of sh*t, it does some what spoil your day. :o :o :o :o
8-)
DaveL
Similar spring, different part number (due to vented rear discs), so you should still have something - its a little cross made from springy steel.
