Thanks MDTM and LB66
Started by TheBoy, 28 April 2007, 20:32:18
Damn decent chaps.  They insisted on 'helping' change the fluid in the tractor's gearbox, despite my objections  :P
Then Marks_DTM was insistant on sorting out the EGR valve (stripped thread), so obviously I had to let him...
In all seriousness, thanks to M_DTM and Laidback66 - it was a job I don't think I could of done on my own.  The box changes much, much better. Still got a naff change point map, I think GM need to do more work on that, but the change is much smoother without the clunking/surging :y
We also found why the gearchange was far from smooth...
So thanks again, really appreciated :y :y
(and anytime you fancy doing the MV6, you only need to ask  ::))
Oh, and Mr McBurger turned up as well, good to see you again Ronnie :y
Why wasn't the gearchange smooth before Jaime?
QuoteWhy wasn't the gearchange smooth before Jaime?
The atf, had there been any in there, would have been dark brown and 'well used'....
Oh, and I forgot, the pair of them also helped fix the check strap on the drivers door. Top blokes :y (and my shins thank you as well!)
Admin
Welcome mate. :)
Now when Mrs DTM is again in a good mood ( :P) we need to nip round there and sort the ATF change on your MV6, ideally while Mark is busy on replacing his kitchen!  ;)
If the gasket is not welded to the gearbox it should only take a couple of hours.
The Administrator.
QuoteWelcome mate. :)
and the plug is not seized...
So can we determine Mrs DTM's mood by the biscuit layout?  ;D
Body language is the key.......
There a fickle creature ...women...
