Ronnie project 2007/2 well under way
Started by Ronald_McBurger, 29 April 2007, 21:12:59
Ronald_McBurger
1999 V reg Facelift LPG ELite
Made a start at last this morning at 9am.  Started with  jacking it up and undoing the drivers side front pipe to manifold. Noted a brand new catalytic convertor and two new oxygen sensors. Nice thanks. Also noted that whoever fitted the cats, decided not to refit the two bolts that secure the cats to the mounting, thus putting the centre joints under strain.
Then started dismantling the rather interesting LPG pipework under the bonnet. Found an immediate problem with it, namely the second intake brass coupler had worn through the rubber adapter ring, and thus was leaking LPG! Explains the whiff of calor gas when you open the bonnet!
Further dismantling revealed an unbelievable mess in the intakes and throttles. Watery brown sludge. Much more dismnatlg revealed the first of several cock-ups by previous mechanical persons. Fisrtly, the 4 breather pipes on the plenum. One looked familiar though not a breather pipe. A bit of checking confimed what I suspected. They had taken the vent hose from teh autobox, and fed it straight into the plenum. Might explain that sludge! The actual breather pipe was carefully hidden behind the fuel lines as they obviously couldn't work out where it should go, so just hid it.
More dismantling confirmed that the oil cooler had indeed been replaced, but they were a little enthusiatic with the sealant. It was everywhere!
Finally got access to the HBV whichg I partially removed to egt access to the main coolant pipe union.  Coolant pipe then removed, followed by both heat shields. All bolts successfully undone with care. Shifted more pipework from the LPG system, to get better access to the manifold. Then switched my attention to removing the air intake box, bagpipes, aux belt, aux tensioner, all pulleys, cable tray, air injection pipework andf finally the timing belt cover.
This revealed that the cambelt wasn't that old, tensioners 'look' ojk, but not new and the water pup looks like the original one. All will be replaced on rebuild.
Now had good access to the manifold, so off it came revelaing an obvious blow from the rear. front pipe gasket had not been replaced on last assembly, so it was blowing there too.
Have decided to remove all 4 cams next week and reprime all 24 hydraulic lifters to get rid of the top end noise.
Laidback arrived and after a cuppa we pressed on with a visit to MarksDTMCalib for a bit of manifold therapy, before returning and fitting the manifold on. Dave had to pop back to Derby for something while I fitted the water pipe perfectly, before realising that once again I had forgotten the bloody heatshields, so promptly took it back off again., Then refitted both heatshiels before calling it a day.
Dave and I had a mission to collect his latest car in York, which turned out to be a bit nearer. Met a nice honest man in a layby who took Daves cash and gave him the keys to a shed.
So. Pics so far..... CLICK ANY TO ENLARGE
Manifold removed, this surface needed cleaning with one bit of very fine wet and dry and one Laidback.
You can see where the manifold gasket has been blowing on this.
.... And close up here
The gaqsket tells a similar tale!
The Drivers side manifold before removal
Top and front end stripped
THIS!!!!! is what was connected to the plenum. It is the autobox vent pipe!
An interesting modification to the air intake box! No pipe, but instead some muppet had duck taped half the airway off!!!!!!!
Oh yes.... erm, the throttle boddies as revealed to me when I removed the intakes!
Good stuff Fin!
If you want any muscle or gadget fingers, give me a shout  :y
Auto Addict
I like red cars
Joneyentee
If I'd realised you were gonna be doing all that I'd have invited myself over for a lesson in car mechanics! ;)
Reading of signatures prohibited...
Admin
#5
QuoteIf I'd realised you were gonna be doing all that I'd have invited myself over for a lesson in car mechanics! ;)
Lessons in mechanics are usually on hand at Mark DTM's.
Ours are more relaxed affairs involving lots of tea, idle chat and the odd bit of tinkering!  ;)
Oh, and Mr McB, it is not just a shed, it is a damn quick sharp handing bright yellow shed that is an absolute blast to drive!  ;D
The Administrator.
Paul M
Don't dismiss this as some random lunatic Irish idea to get more power ;) it may actually be to do with the LPG system; I've heard of cases where too much flow into the airbox could cause some systems to stall, and the bodge solution is to partially restrict the flow into the airbox. Basically it's a poor fix to a problem that should be fixed properly instead, but bear it in mind if you get problems trying to run it on gas.
Markie
i did pick up in Ronnies original post about Daves new shed....
and its yellow - so not omega......perhas sierra alpha alpha bravo ??
Great picces Ronnie  :y
Ronald_McBurger
To be fair, Daves new shed is a low slung, sports car that actually nearly kept up with my Corsa 1.2 occasionally. OK, if I am honest I actually like it. It is NOT an omega. It is very stylishly designed by one of Italy's finest designers, it is VERY fast and I get the distinct impression that Dave will be keeping this for himself.
Markie
surley not a fiat coupe......by pinafarina..... :-/
Admin
Indeed, powered by the engine that sat in the Delta Integrale!  8-)
Alas it has been bought for the other half so I can get the MV6 back!!  ::)
Has to be said, it is an absolute hoot to drive!
I know it will break down (often!) but I can forgive something this much fun.
The Administrator.
Markie
QuoteIndeed, powered by the engine that sat in the Delta Integrale!  8-)
i am surprised  ;D but all is fair in love and war and the winning of MV6's  :y
Yes, more recently remembered for its legendry status in the Fiat Tipo.... :y
QuoteAlas it has been bought for the other half so I can get the MV6 back!!  ::)
I still say you should have bought her a Cinqucento....with aircon....particularly given how often she changes her mind....only last week she wanted a diseasel for the economy..!
Admin
I suggested the Coupe to her. I could not face another bl**dy tractor!  ::)
Got to sort this annoying low rev whine though (not her either!).... :-?
The Administrator.
