Author Topic: sizes needed  (Read 2238 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
sizes needed
« on: 30 August 2010, 10:36:09 »
Now i Know i need a 45T hex to remove the sump plug on my facelift but can anyone remind me of the size of spanner needed for the removal of the end of the Oil filter cap.
Just about to run upto Toolstation to get an oil pan for old oil.
Thanks all
Steve
Re: sizes needed
« Reply #1 on: 30 August 2010, 10:43:31 »
22 or 24 iirc
SP_3.2
  • Leicester
Re: sizes needed
« Reply #2 on: 30 August 2010, 10:48:16 »
Cool thanks Tunnie will pick up one of each :y :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: sizes needed
« Reply #3 on: 30 August 2010, 11:11:34 »
I'm no expert but the plastic oil filter cap (insert type) on my Vauxhall was much bigger, around 34 m.m. if memory serves.
Maybe you should just stick a ruler across the flats of the 'nut'?
Re: sizes needed
« Reply #4 on: 30 August 2010, 11:12:51 »
Definitely not 34 mm, as Tunnie  says, it's either 22mm or 24mm  :y  :y
Re: sizes needed
« Reply #5 on: 30 August 2010, 11:18:12 »
Thanks all
Steve
You can either use a 15/16ths spanner on the external 'nut', or a 3/8ths socket drive in the internal square within the lid if it is not rounded ;) ;)
Re: sizes needed
« Reply #6 on: 30 August 2010, 13:46:38 »
You can either use a 15/16ths spanner on the external 'nut',  .....
15/16"th = 23.8 so near enough to 24mm spanner  :y  :y
Re: sizes needed
« Reply #7 on: 30 August 2010, 14:01:37 »
But not near enough Andy when you go to use a 24mm spanner!  ;) ;) ;)   Only a 15/16ths I have found actually fits snuggly enough to deal with a filter cap well on! 8-) 8-)
Re: sizes needed
« Reply #8 on: 30 August 2010, 16:33:18 »
My 24mm must be a closer fit than yours then, I'm not sure the last time I saw a 15/16" AF spanner  :y  :y  :y (outside of work  ;))
serek
  • huntingdon
    • 3.2 mv6
Re: sizes needed
« Reply #9 on: 30 August 2010, 19:02:53 »
plastic cap 36mm :y
Brikhead
  • West-Mids.
Re: sizes needed
« Reply #10 on: 30 August 2010, 19:06:18 »
Must be different on the Omega? I suppose I should go out side and look before posting, in future!
Ken T
  • Stockport
Re: sizes needed
« Reply #11 on: 30 August 2010, 19:34:13 »
if you can get it in, a chain wrench does the job well, plus it will fit other sizes.
Ken
kcl
  • Finland
    • Volvo V60 D4 -14
Re: sizes needed
« Reply #12 on: 30 August 2010, 19:38:06 »
24 mm for the cartridge type canister "cap", 3/8" square recess in the middle.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: sizes needed
« Reply #13 on: 31 August 2010, 20:15:58 »
That's no way to treat your monarch! ;D
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: sizes needed
« Reply #14 on: 31 August 2010, 21:28:10 »
Thanks all
Steve
You are a women after my own heart Lizzie :-* I always use a 15/16 ths Spanner too ;)
