Pages: 1 [2] 3  All   Go Down
Author Topic: EGR valve blanking plate  (Read 7080 times)
MartinP
  • Dudley
    • BMW 320D
Re: EGR valve blanking plate
« Reply #15 on: 21 December 2006, 13:40:32 »
Just a quick one.....are the existing torx bolts long enough to accomodate the blank?
Yes they are long enough as the plate is half the thickness of the valve flange. What I don't know is if the bolts are too long!
Are the holes in the maifold "blind", and what depth are they?
Or put a thick washeror two on the bolt.
Paul M
  • Edinburgh
« Reply #16 on: 21 December 2006, 13:40:58 »
I'd love one of these, but unfortunately that type won't fit my engine :(
Any chance of making one for the newer style EGR that is bolted on to an extension pipe thing? There are three torx bolts holding it onto the plenum. Mine is currently blanked off with an IRN-BRU can, and I'm pretty sure it's not airtight cos I've got a lumpy idle.
I don't have a picture here just now but can take one if you need it. I'm sure someone has a spare one or two of these lying around :)
Cheers!
MartinP
  • Dudley
    • BMW 320D
« Reply #17 on: 21 December 2006, 13:44:26 »
Ok, so PM is definitely working. All who would llike these plates PM your address and I'll bang them out asap.
I can get as many of these as is needed, as the program is saved at work, so there's no panic
Sorry issunaz, I'm in IT... you saved it on a computer ??? Now I'm worried....  ;D
You know how the saying goes;
To ERR is human, to really F*%K things up, it takes a computer PROGRAMMER
 ;D ;D
« Reply #18 on: 21 December 2006, 13:44:52 »
Remember that you will need to keep the EGR valve to prevent error codes appearing...so it would be best to sandwich the plate between the EGR valve and the mounting flange.
MartinP
  • Dudley
    • BMW 320D
« Reply #19 on: 21 December 2006, 13:47:33 »
Cheers!
as long as it can be cut out of flat steel,
Let me have a dimensioned sketch and it shouldn't be to hard.
MartinP
  • Dudley
    • BMW 320D
« Reply #20 on: 21 December 2006, 13:49:28 »
these are 3mm thick,   :(
may have been better with 1.5mm  :-/
Paul M
  • Edinburgh
« Reply #21 on: 21 December 2006, 14:09:44 »
Cheers!
Cool, cheers. Does anyone have one of these type of EGRs lying around off the car? It would be pretty easy to sketch that way, unfortunately I can't remove mine cos one of the bottom bolts won't budge - bent the teeth on a Torx socket trying! The ones on the manifold are no bother, hence the IRN-BRU can ;)
Just thinking, maybe I can just get a gasket to use as the outline and either trace that or send you one.
MartinP
  • Dudley
    • BMW 320D
« Reply #22 on: 21 December 2006, 14:27:19 »
Cheers!
Gasket is good, thats how I did mine  :)
« Reply #23 on: 21 December 2006, 15:09:54 »
I could desperately do with one if there's one going...
Craig_R
  • Watford
« Reply #24 on: 21 December 2006, 15:13:27 »
I hate sounding like a thicky but where would the EGR valve be on a 2litre engine ?
Craig
Mod's
[To be Fitted]Reverse Sensors
Paul M
  • Edinburgh
« Reply #25 on: 21 December 2006, 15:39:41 »
Cheers!
OK I was planning on buying a replacement gasket for mine to try and cure the poor idle so I'll pick up two instead and send you one. Probably next week I expect... will keep you posted.
Bo Bo
  • Coventry
« Reply #26 on: 21 December 2006, 15:57:15 »
Don't worry, you're not the only one lost on this........
Markjay
  • London
« Reply #27 on: 21 December 2006, 17:27:25 »
Craig
According to Autodata it is somehwere around there:
Alas, no more Omegas....
« Reply #28 on: 21 December 2006, 18:02:41 »
So, if the valve is removed and blanked, do you get any fault codes/lights.
also will the car still get through the MOT?
Yes, you will get EML and stored code if egr unplugged electrically.
MartinP
  • Dudley
    • BMW 320D
« Reply #29 on: 21 December 2006, 23:23:35 »
Is it the same valve on the 2.0l  ??
Pages: 1 [2] 3  All   Go Up
