Author Topic: Why you should have a sander/polisher  (Read 3316 times)
Knight3179
  • Stromness,Orkney
« on: 08 September 2010, 20:03:35 »
From this
to this
Most won't tell the diff, til we turn off the flash
There you go, these machines are worth every penny,
Little elbow grease with some foam rubbing compound
Finished with Ice Wax
Rest of car be done tommorow,
then the wheel refurb
Mysteryman
Re: Why you should have a sander/polisher
« Reply #1 on: 08 September 2010, 20:05:12 »
Looks great :y
But it's black :-/
Five minutes in the rain and... ;D
Bent valve
« Reply #2 on: 08 September 2010, 20:11:18 »
Whats that on the boot ?have you been trying your hand at artificial insemination..
Knight3179
  • Stromness,Orkney
« Reply #3 on: 08 September 2010, 20:33:37 »
Led work lamp smarty mcpants ;D ;D ;D
The wax i use creates beading with water and tar won't stick to it :y
« Reply #4 on: 08 September 2010, 20:48:08 »
agreed.. saves effort and time.. :y
Bent valve
« Reply #5 on: 08 September 2010, 21:19:27 »
Artificial insemination?
« Reply #6 on: 08 September 2010, 21:40:44 »
what ? where ? who ?
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #7 on: 08 September 2010, 22:36:10 »
It's true !  Straight up, no bull !!  ::)
« Reply #8 on: 08 September 2010, 22:40:07 »
Coat ........
Door! .........  ;)  ;)  ;)  ;)
« Reply #9 on: 08 September 2010, 22:43:41 »
Splendid 8-) :y
« Reply #10 on: 09 September 2010, 10:51:20 »
I must make a warning for those who plan to buy polishers .. Never use it under direct sunlight on a hot day.. You may damage the paint..So use it in shadow..
Also using diferent heads from coarse to finer with coarse to finer paste is necessary.. But which one to start with depends on the condition of paint.. :y
edit : buy the models with variable RPM ..and use always the lowest until you learn the job.. cheapo chinese made models have a short life.. so stay away..and always use clean or cleaned and wettish heads..
« Last Edit: 09 September 2010, 10:56:08 by cem_devecioglu »
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #11 on: 09 September 2010, 11:11:40 »
Any suggestions for a decent reasonably priced polisher??
davethediver
  • Blackburn, Lancs.
« Reply #12 on: 09 September 2010, 11:46:12 »
THe meguairs g220 seems to get good results john not the cheapest though but it is a a dual polisher so oscilates as well meaning your less likely to balls it up take too much off when you first start :y
P.A. Caron de Beaumarchais
Knight3179
  • Stromness,Orkney
« Reply #13 on: 09 September 2010, 11:54:20 »
Mines a silverline bought from amazon, variable speed so won't rub too hard, looks like a big angle grinder, those handheld polisher are no use as you need to put alot of weight on them to keep the bonnet from flying off, Silverline polisher £40 plus P&P amazon, sealey M14 compounding heads £10 each
« Reply #14 on: 09 September 2010, 12:15:10 »
I take mine down to the car wash and hand it over to one of the immigrants.
