Author Topic: Corner protectors  (Read 2438 times)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Corner protectors
« on: 08 October 2010, 16:03:48 »
I know peeps on here like answering weird questions so here goes....
I need some of that industrial plastic right-angle strip that you glue on corners of walls to stop trolleys destroying the plasterwork.  I can find manufacturers but need a small outlet for a couple of 1.5m lengths.
Searching DIY websites turns up nothing useful.
Any (helpful :)) ideas?
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Nickbat
Re: Corner protectors
« Reply #1 on: 08 October 2010, 16:17:57 »
Welung666
« Reply #2 on: 08 October 2010, 16:19:07 »
redelitev6
« Reply #3 on: 08 October 2010, 16:22:38 »
Try somewhere that does perspex signs, or a proper builders suppliers,( especially if they supply hospitals/schools etc)if they haven't got it in stock they might be able to source some for you
Chris_H
  • E London/Essex UK
« Reply #4 on: 08 October 2010, 16:29:07 »
Right thanks for those, guys.  I didn't see the B&Q stuff even though I'd scoured the website.
It was more substantial stuff that I was hoping for; sort of 100mm-ish like in hospitals
Welung666
« Reply #5 on: 08 October 2010, 16:48:20 »
In that case you want the sort of stuff we have here (primary school) that we get from here:-
http://www.bliby.net/products.php?id_page=52
Search down for 'Solid PVC Angles', they go from 1" up to 4" :y
« Reply #6 on: 08 October 2010, 17:48:45 »
have a looksie on ebay, most things are sold there.
Chris_H
  • E London/Essex UK
« Reply #8 on: 08 October 2010, 19:16:24 »
That's getting close although 1.5mm thick is not going to take a canteen trolley at char-lady speeds I suspect.  This is for a church kitchen I've agreed to decorate.  EHO don't like the possibility of germs stuck in the gouged plaster.
I can find manufacturers but no outlets.  May have to ring one.
try this http://cgi.ebay.co.uk/CORNER-PROTECTOR-WHITE-500MM-LONG-50MM-X-50MM-LEGS-/120465...
I don't think they go to 1.5m long.  Would need 3 on each corner and EHO don't like joins 'cos of germs. :(
« Last Edit: 08 October 2010, 19:20:49 by ChrisH174 »
Mysteryman
« Reply #9 on: 08 October 2010, 19:31:20 »
Fabricate some from sheet aluminium.
I said 'sheet' aluminium.
Chris_H
  • E London/Essex UK
« Reply #10 on: 08 October 2010, 21:53:40 »
I'd need a bender.  Are you volunteering?
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #11 on: 09 October 2010, 00:57:24 »
have you tried the corner shop?
Welung666
« Reply #12 on: 09 October 2010, 08:40:27 »
It takes PE trolleys and the lunchtime hot trolley without a mark! They are 'no more nailed' on and sealed around with silicone and have taken many a knock but are still perfect.
Any thicker and your getting towards cladding stuff!
Richie London
  • heathrow
« Reply #13 on: 09 October 2010, 09:19:54 »
Mysteryman
« Reply #14 on: 09 October 2010, 09:23:23 »
That derserves more than it got... ;D ;D ;D ;D :y
