Author Topic: Why ?  (Read 1473 times)
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Why ?
« on: 27 October 2010, 12:13:27 »
Can anyone tell me why lamps/bulbs go black/silvery inside .
Is it over voltage ie excessive temp or maybe a leak allowing air in Any suggestions  :D
Re: Why ?
« Reply #1 on: 27 October 2010, 12:18:40 »
It's the metal filament gradually evaporating and being deposited on the inside of the glass envelope.
Re: Why ?
« Reply #2 on: 27 October 2010, 12:35:10 »
LFF64
  • HADDENHAM BUCKS
Re: Why ?
« Reply #3 on: 27 October 2010, 13:11:57 »
Thanks Kevin
But what causes this  :question
Re: Why ?
« Reply #4 on: 27 October 2010, 13:16:12 »
Thanks Kevin
Old age, sounds like us when we go grey.   :-/
maria
  • Derbyshire
  • I'm proud to be welsh :)
Re: Why ?
« Reply #5 on: 27 October 2010, 13:32:23 »
Thanks Kevin
[/highlight]
You've gone grey skrunts ;D ;D
Sixstring
  • Lydney, Gloucestershire
Re: Why ?
« Reply #6 on: 27 October 2010, 13:35:39 »
Or BALD...................................... :'( :'( :'(
(or like me, BOTH.)
Some things are meant to be bald, my head isn't one of them!!
Re: Why ?
« Reply #7 on: 27 October 2010, 18:05:04 »
Its age/usage...
maria
  • Derbyshire
Re: Why ?
« Reply #8 on: 27 October 2010, 18:06:22 »
(or like me, BOTH.)
[/highlight]
Your not wrong there......
 :-X :-X :-X ;D ;D
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
Re: Why ?
« Reply #9 on: 27 October 2010, 18:18:16 »
a little more on why.....    based on theory, not sad enough to have done much experimental observation....
evaporation of the element materials...
when you heat something so it's that hot, some of the material is evaporated....   heat is basically highly agitated molecular movement, the hotter something gets, the eaiser it is for molecules to escape , whether it's a solid or a liquid,  so,  slowly, but surely, material leaves the element,   and since the coolest thing in the bulb is the glass, it condenses on the glass, leaving a fine slivery deposit...
when a filament fails , it would seem a lot more does it at once, i'd surmise that as the filament breaks , so the arcing that happens as it begins to separate, vaporises  fair bit more material quite rapidly,   so the sudden "plating" of the inside of the glass.
of course, if any of this is wildly inaccurate i'd be happy to be corrected.....
tidla
  • solihull
Re: Why ?
« Reply #10 on: 27 October 2010, 18:39:13 »
just put a new one in and find something else to do ;D
