Author Topic: Oil Filters?  (Read 3468 times)
Taxi_Driver
Oil Filters?
« on: 09 May 2007, 15:55:30 »
Got sold the wrong one today by vx dealer  >:(
I didnt notice at the time coz i was buying quite a few bits.
Still used it....coz i couldnt be bothered to take it back
Should have been sold 93156954 @ £4.09 +vat retail
What i was sold was 93178952 @ £2.91+ vat retail
Both are metal canister type.....but the cheaper one has LONG LIFE  :o printed on it.
Whats the difference.....anyone know? and does it matter?  :-/
Nickbat
Re: Oil Filters?
« Reply #1 on: 09 May 2007, 16:15:18 »
The Long Life one doesn't need to be kept in the fridge. ;D
Sorry, couldn't resist it.  ;)
Re: Oil Filters?
« Reply #2 on: 09 May 2007, 16:28:02 »
Make sure it's got the correct thread on it. Otherwise, it may fall off and unless you shut it down very quickly it's going to cause damage. It'll cause a mess whatever happens. If it screwed in OK and tightened up it SHOULD be OK.
Other than that the differences are whether it has a bypass valve (doesn't really come into it if you change it before it clogs up!) and the size and shape of the filter. If it physically fits and the thread is the same (sometimes stamped into the inside surface next to the threaded hole) I'd say it'll be fine.
Taxi_Driver
Re: Oil Filters?
« Reply #3 on: 09 May 2007, 17:21:57 »
It looked the same size.....and it fitted ok.
Cheers  :y
Re: Oil Filters?
« Reply #4 on: 09 May 2007, 21:10:58 »
If it came from a VX dealer it'd be unlikely to have a different thread IMO. They hopefully standardise on one size.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Oil Filters?
« Reply #5 on: 09 May 2007, 21:41:52 »
The long life ones have a restricted oil flow, only 10% of the oil gets filtered, hence the long life.
In the short term, this will cause major long lasting  damage to the Omega 2.2 engines.
On tests, it caused oil starvation to the cam shaft causing the engine to blow after only a few hundred miles.
Only joking TD ;D
I like red cars
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Oil Filters?
« Reply #6 on: 09 May 2007, 21:43:36 »
AA you had me there  ;D
Joneyentee
  • Derby
Re: Oil Filters?
« Reply #7 on: 09 May 2007, 22:23:33 »
Ahh geez. That's so bad I should've said it!.
And you had me going for a sec there AA!  ;D
Reading of signatures prohibited...
Markjay
  • London
Re: Oil Filters?
« Reply #8 on: 10 May 2007, 00:15:39 »
Well done AA  ;D
Alas, no more Omegas....
Markjay
  • London
Re: Oil Filters?
« Reply #9 on: 10 May 2007, 00:19:04 »
On a serious note, some filters have two valves, i.e. apart from the by-pass valve they also have a non-return valve that is meant to prevent the oil from dripping back into the sump when the engine is switched-off. This ensures that the filter is full of oil when the engine is started from cold next time. Not sure if this is relevant to the issue at hand, info supplied for general knowledge....
Taxi_Driver
Re: Oil Filters?
« Reply #10 on: 10 May 2007, 06:17:59 »
Thanks for the info AA  :y Will get it changed ASAP   ;)
