Author Topic: TV Remote  (Read 1950 times)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
TV Remote
« on: 29 October 2010, 15:55:19 »
The tv remote has stopped working, well it's still flashing the ir diode but the tv doesn't respond.
Tv will work with the MCE remote to switch on/off but not the dedicated tv remote.
On comparison the tv remote seems brighter than the MCE which is working.
Any suggestions?
Batteries changed already and battery connections cleaned with a file.
TuBy's new whipping boy.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: TV Remote
« Reply #1 on: 29 October 2010, 17:04:46 »
When you say it's flashing the IR diode I presume you mean that the LED on the TV flashes when you press a button on the remote?  IR is invisible.
Does the remote have a switch for TV/VCR etc?  If so it could be sending the wrong codes if it's moved.
« Last Edit: 29 October 2010, 17:05:46 by ChrisH174 »
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: TV Remote
« Reply #2 on: 29 October 2010, 17:11:04 »
use your camera phone to look at the IR sender to see if it flashes :y
the LED is just a flashing light
Amigo
  • Immingham N.E Lincs.
  • Be objective, be selective.
    • Passat & Cortina GXL
Re: TV Remote
« Reply #3 on: 29 October 2010, 18:02:34 »
Switch the telly off & have a beer John! 8-)
Mysteryman
Re: TV Remote
« Reply #4 on: 29 October 2010, 18:22:49 »
It's f**ked. Buy a new one.
Debs.
Re: TV Remote
« Reply #5 on: 29 October 2010, 18:27:05 »
Buy a new one.
 :y A three musketeer`s type: "One for all" ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: TV Remote
« Reply #6 on: 29 October 2010, 19:06:51 »
Yes that's what I meant the sender is an ir emitting diode is it not.
Plomien
  • Swansea
Re: TV Remote
« Reply #7 on: 29 October 2010, 20:11:08 »
its fubar then time to buy a new one
Debs.
Re: TV Remote
« Reply #8 on: 29 October 2010, 20:40:51 »
If you have a CCTv camera (house/garden security type) available, then with any visible lights off, you should be able to clearly check the remote`s IR diode output via the camera/CCtv.; as such 'cheap' CCD camera`s are surprisingly sensitive to IR light...the output will show up as a bright flickering beam when any button is pressed on the remote. ;)
Plomien
  • Swansea
Re: TV Remote
« Reply #9 on: 29 October 2010, 20:43:50 »
same as a mobile phone camera ;)
Re: TV Remote
« Reply #10 on: 29 October 2010, 20:49:25 »
Less common these days but, some years ago it was not uncommon for the oscillators to go wappy (they are ceramic resonators).
The IRDA still outputs but the bit rate is wrong.
Debs.
Re: TV Remote
« Reply #11 on: 29 October 2010, 20:51:57 »
 :-[ :-[ Note to self: read the prev. posts :-[ :-[
 ;)..... ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: TV Remote
« Reply #12 on: 29 October 2010, 21:33:19 »
Sounds like TG will be attacking it with the soldering iron then. ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: TV Remote
« Reply #13 on: 29 October 2010, 21:34:34 »
Turning on my laptops webcam works for me. :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: TV Remote
« Reply #14 on: 29 October 2010, 22:23:19 »
The resonator is coded as 400CM630 but what value will that be?
It looks identical to this but the coding is different obviously.
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5266097
