Author Topic: ronnie project 2007/2 update again  (Read 1432 times)
Ronald_McBurger
« on: 10 May 2007, 11:52:02 »
Today fitted the replacement exhaust system and passenger side Cat. What a difference!!! Full power restored. Problem area is the centre section to cat joint that just won't seal. Crap design and may need some modding. Had to drill out one bolt first then used a nut and bolt on that side.
Other matters? The hiss was from the totally fubared air injection rubber joints, both split to heck. Replaced with some old radiator hose for now, but will source the right ones later.
Wishbones may need doing. car does seem a little vague.
Tappets still noisey (ish) and afetr the run at tickover oil pressure light is coming on which would explain it. Spoke with Mark last night and it would seem the oil pressure relief valve may be stuck. Means stripping back to cambelt again to access the sodding thing and also means a new TX bit set for me again!
Gearbox is fine, power is there and car goes ok. Still some work to do yet and some more spending :( but car will be good when done soon.
Admin
Re: ronnie project 2007/2 update again
« Reply #1 on: 10 May 2007, 12:24:01 »
Good to hear the exhaust is sorted. :)
Now, the pressure relief valve.... To quote Mark ;)
"I told you so!"  ;D
The Administrator.
« Reply #2 on: 10 May 2007, 14:01:15 »
One other thought....its had running issues......the top end is very clean.....the oil is clear.......have you changed the oil yet...
It might have had some bore wash and got neat fuel into the oil, this would thin it out and cause low oil pressure....would clean the internals nicely to...
Ronald_McBurger
« Reply #3 on: 10 May 2007, 14:29:48 »
oil change tomorrow anyway. running some flush through it first for 10 minutes, then new oil and filter. then 100 miles and another oil/filter change.
« Last Edit: 10 May 2007, 14:30:04 by Ronald_McBurger »
Admin
« Reply #4 on: 10 May 2007, 17:49:49 »
I want a brain that works like Marks..... ;D
The Administrator.
« Reply #5 on: 10 May 2007, 18:05:23 »
I could do with a Mark in my toolbox ;D
Joneyentee
  • Derby
« Reply #6 on: 10 May 2007, 23:03:46 »
I'd settle for one that works at all!  ;D
Reading of signatures prohibited...
