Make your oil go further.....dilute it like mine!
Started by MartinP, 19 August 2006, 22:24:51
That engine didn't get many coolant changes ....
Heads will probabaly want a skim and re-build before any re-use.
I love stripping engines down, much easier when removed to.
STMO123
Am I right in thinking that the oil cooler wasn't so much of a problem on later engines?
Markjay
QuoteAm I right in thinking that the oil cooler wasn't so much of a problem on later engines?
So did I. They replaced them with stainless steel units bla-bla-bla, but the oil cooler failed on my 2001 2.6 engine at around 30,000 miles / 3 years! luckily the car was (just) still under warranty. So sadly they do fail, even on older models and younger engines!
Alas, no more Omegas....
MartinP
Quote?????????? !!!!!!!!!!!!!!!!!!
'...and then, late in the afternoon, having nothing better to do for the remains of the day Issunaz removed the engine from the Omega and dismantled it, as one does....'
Ahhhmmmm......
it was after i got to this stage
swept up three time, had a cup of tea, then dismantled the engine  ;)
Markjay
Ahhhmmmm......
Issunaz, you are a dangerous man with that jigsaw...  ;D
Markjay
When I saw your first picture, I was wondering why you took the engine out with the gearbox attached. Now I realised that what you actually did is cut the car away in bits until all was left was the engine and gearbox...
