Make your oil go further.....dilute it like mine!
Started by MartinP, 19 August 2006, 22:24:51
MartinP
Got this when I took the oil filter off
Fortunately it was the 2.5 engine that I stripped  :)
MartinP
"water in the oil" thats the head gasket I believe.
Quote"water in the oil" thats the head gasket I believe.
Water in the oil could also be the Oil cooler failing/failed on the V6 models. Although there's a possibility of Headgasket trouble in this situation, I understand the V6 HGs are very resilient, and this is usually a cooler failure.
johnny.dee
they way I understand it is,
Water in oil, head gasket.
Oil in water, oil cooler.
That amount of water in oil is most likely HG I fear...
Markjay
Hmmm... does not look good.... have you checked for other HG tell-tale signs? Droplets with antifreeze smell in the exhaust fumes? Compression test?
Alas, no more Omegas....
Could still be oil cooler, it dumps a fair amount of water into the oil when the engine is stopped if its failed.
Do you do them with a flake?
Auto Addict
I like red cars
MartinP
I did try to post yesterday but got fed up when photobucket crashed the computer twice.
The waterways are all oil free and dry, as is the outside of the oil cooler (have taken loads of pics stripping the engine down)
MartinP
#10
1 head off
MartinP
Markjay
#13
'...and then, late in the afternoon, having nothing better to do for the remains of the day Issunaz removed the engine from the Omega and dismantled it, as one does....'
Ahhhmmmm......
MadOnVaux
#14
Cheers...could just go a pint of Boddingtons  ;) ;D
*B#st#rd!, why dont those pics work when quoted?
