Author Topic: Qantas Has Omega Problems!  (Read 1152 times)
« on: 08 November 2010, 15:37:02 »
Following on from the engine blowout on one of its Airbus A380s the other day, it seems they have oil leak problems on three more engines:
http://www.bbc.co.uk/news/world-asia-pacific-11707459
I half expect to read that it is oil leaking from the cam covers!! :D :D :D :D
So far it is being stated that the way Qantas operates the Rolls Royce engines is different from other A380s with different airlines, and seems it may be the cause of the problem.  I think I understood it was something to do with oil pressure specification.
Is that a sign they haven't been cleaning the breathers? :D :D :D :D ;) ;)
« Last Edit: 08 November 2010, 18:25:28 by Lizzie_Zoom »
Re: Quantas Has Omega Problems!
« Reply #1 on: 08 November 2010, 15:58:53 »
Hmm. I wonder by what process oil leak turns into turbine blades exiting the top of the wing? Still plenty to investigate, I think.
"We are keeping an open mind on it but... We think it could have been a materials issue on the engine, or a design issue."
In other words, "Not our fault". Absolutely nothing to do with us using GM 10w40 'cos it's 4 for the price of 3. ;)
Debs.
« Reply #2 on: 08 November 2010, 15:59:33 »
It`ll be dis-pack changes and HBV leaks next! ;D
« Reply #3 on: 08 November 2010, 16:01:10 »
Well, with this new "self-dismantling" feature, the DIS pack should be much easier to get to. ;D
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #4 on: 08 November 2010, 16:55:36 »
Operational issues - have they Please read the manual?
HIGH-POWER take-offs used by Qantas A380s on trans-Pacific routes could be
responsible for potentially dangerous oil leaks now under scrutiny as a
possible factor in last week's engine explosion near Singapore
Engineers believe the higher thrust levels at which the carrier operates its
Rolls-Royce Trent 900 engines may result in resonating vibrations that cause
oil lines to crack.
The theory has emerged after in-depth inspections uncovered oil in three A380
engines in areas where it should not be present
All three engines are being replaced as the airline continues with its regime
of rigorous checks in the wake of the near disaster on flight QF32 last
Thursday
The Qantas A380 involved, which came into service two years ago, was also used
for the Continued on Page 2 Continued from Page 1 trans-Pacific story. The oil
leaks in the three engines, found in the intermediate pressure turbine area
housing a disc similar to the one that disintegrated in last week's spectacular
mid-air drama, caused spotting and pooling that had the potential to spark
damaging fires in the engine
An August oil fire in the same area of a Trent 1000 engine, a derivative of the
900, is believed to be responsible for an uncontained failure on a test bed in
Britain
Qantas A380s have a maximum thrust setting of 72,000lbs, higher than fellow
Trent 900 operators Lufthansa and Singapore Airlines but still 3000lbs below
the design limit of 75,000lbs. It uses the extra thrust for maximum weight
take-offs on the long-haul routes between Los Angeles, Sydney and Melbourne
The extra thrust is particularly important on the Melbourne route which, at
more than 15 hours, is the longest in the Qantas network
Engineers from Qantas and Rolls-Royce had been looking for reasons the oil
leaks had been found in Qantas planes but had not turned up in inspections
performed by Singapore Airlines and Lufthansa. They were particularly concerned
the engines were relatively new, with the damaged engine on QF32 having
recorded just 900 landings and take-offs before it flew apart
The engines on the three planes are identical except for a computer chip that
defines the maximum power rating and the engine is certified to operate at the
higher thrust level
The engineers arrived at what is now the flying kangaroo's lead theory after
considering whether the engines might be acting differently during operations
from their performance in factory tests
If the theory pans out, the hope is that Rolls-Royce can devise a way of
operating the engine on take-offs and climbs that does not produce the damaging
resonance
The airline is continuing to inspect for other potential engine faults, but
Qantas chief executive Alan Joyce said yesterday the focus of the investigation
had narrowed in terms of the oil leaks and he was comfortable it was on the
right track
Mr Joyce said the leaks should not be occurring and were outside the normal
specifications and design of the aircraft. He said it was too early to be
definitive on what the issues causing the engines to perform outside normal
parameters were, or how long they would take to be repaired
"We are working very closely to get a speedy recovery on this, but I won't
comment on how long it will take until that investigation is completed, " he
said
Mr Joyce said the airline would not resume flying the A380s until it was 100
per cent sure its operations were safe. It has already replaced one of the
three affected engines, has a second spare ready to go and is working with
Rolls-Royce on finding a third.
« Reply #5 on: 08 November 2010, 17:00:36 »
Thanks for that great explanation pscocoa :y :y :y :y
« Reply #6 on: 08 November 2010, 17:06:44 »
Ah the old .. "The engine dies if I use full throttle" - "The engine is not designed to use full throttle" argument..
I've owned some cars like that! ;D
« Reply #7 on: 08 November 2010, 17:07:31 »
higher thrust level
Ahh, so they were chipped. :-?
« Last Edit: 08 November 2010, 17:07:57 by Kevin_Wood »
« Reply #8 on: 08 November 2010, 17:09:52 »
One question though is does the increase in throttle pressure increase oil pressure in these engines? :-/ :-/
« Reply #9 on: 08 November 2010, 17:19:55 »
Sounds to me like the extra thrust has caused vibrations that are causing something in the oil system to break - either because they chose a bad speed to govern it to at full thrust, or because the engine isn't rigid enough.
« Reply #10 on: 08 November 2010, 17:30:41 »
higher thrust level
Do you think they declared it to their insurance company? ;)
« Reply #11 on: 08 November 2010, 17:35:05 »
Thanks Kevin :y :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Qantas Has Omega Problems!
« Reply #12 on: 08 November 2010, 22:46:49 »
Great shame, as I operated the RB211 in Tristars for 14 years, and never had to shut one down in anger in flight. It was a wonderful design - eventually - I predict that once they have sorted this issue it will go on for many more years. :y
« Reply #13 on: 08 November 2010, 22:55:34 »
Qantas have nothing to worry about then if they were rated to 75k of thrust, and only using 72k... Rolls Royce are in a spot of bother then.
Boeing must be hoping this might increase the order book of their new 787!
Martin_1962
« Reply #14 on: 08 November 2010, 23:32:22 »
They also use a Trent
I am more worried about RR but I think they will fix it
Page created in 0.083 seconds with 16 queries.
