Gearbox change success - 5th time lucky!
Started by JamesV6CDX, 11 May 2007, 21:44:50
When fitting the gearbox for the 5th time this evening.. all went well. The bellhousing went straight up against the block, and I was then able to attach the torque converter to the driveplate through the access panel in the box. Access in there is tighter than a ducks doo-da.. but I got there.
The engine would then spin freely on the crank pully, and I could hear the torque converter moving. I'm sure you're dying to know what the problem was?
Well... although I HAD lined up the torque converter with the Dogs, it wasn't sitting right back on them properly. So credit goes to Markie (who was with me for the 5th attempt).. for using a "persuasion tool" to get it back further in the box. This did the trick.
So, all bellhousing bolts tightned, breather fitted, electrics fitted, linkage fitted, selector switch fitted, cats and exhaust fitted, O2 sensors fitted... propshaft and prop coupling fitted.. gearbox back on mounts...
I am alive, well, and have the use of all my limbs!
My arms and legs feel like they are hanging off, my hands are scrached to peices, my face has been covered in ATF.
And I just realised that, I've been so wrapped up in the car, that I've not eaten for over 36 hours!!!!!
Changing a gearbox on your own 4 times over, for no result, is not any fun... but at least I've had a workout.. and this has certainly been a learning exercise for me!
I now feel very good about myself!
The icing on the cake is.. I've taken it for a short run.. and it's NOT in limp mode, and is changing through the gears very well. So if that remains well... then the old box must have been shagged.
Next job, which it needs NOW, is an Auto fluid change.
So, the plan now, is get some grub, and drink a beer or 10!!!
Mark, thanks again for your ongoing help and support
Matchless - thanks for the ideas about the Dogs.. you were certainly very close!!
If this continues to behave itself, then I will do an ATF change, get my Elite 16" wheels on.. and I will have a VERY sorted Elite!!
Martin_1962
Well done - I have removed manual boxes before but aluminium cased and a lot lighter than the one you did :y
Markie
excellent result and i bet your really really chuffed  :y albeit sore  :(
STMO123
Good grief James! Have a good rest lad. Very well done :y
Well done James
So tonight you will be lying in bed on your back with your arms up in the air ::) ;D
STMO123
QuoteWell done James
Oh no. He'll be much too tired for any of that malarky :D
It's tomorrow night I'm seeing my girlfriend... :P
smoothomega
If at first you dont succeed try try again and again and again and again and again and you will get there ::) Well done James and i'm sure it was well worth all the swearing, well it may not seem it at the minuite but it will be :y
Joneyentee
QuoteGood grief James! Have a good rest lad.
Ignore him! Quit slacking and get on with the ATF change. Eating can wait!  ;) ;D
Grats on a job well done. Hope all is plain sailing... well, smooth running... from now on.  :y
Reading of signatures prohibited...
ATF change is happening next Thursday...When I'm off
Apart from tomorrow.. I will be going to work on the train between now and then...
Auto Addict
I like red cars
Good job....that measurement check is the key for this job it would appear......
Admin
Well done James, another job to add to your Omega CV.  :y
The Administrator.
Bo Bo
Nice one James, glad to hear you got there  :y
Taxi_Driver
Well done James....and fingers crossed this autobox behaves for you  :y
