Author Topic: Traction Control  (Read 1284 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Traction Control
« on: 19 December 2010, 07:55:04 »
Birmingham had a bit of snow yesterday, which snarled the whole area up.
It took me 3 hours to do a 10 mile journey.
I was listening to Radio WM, people were phoning in with traffic reports, and then a plonker came on and said :-
The reason cars are getting stuck on hills is because they have their TC control ON, they need to turn it OFF :o.
So the presenter took this up, and advised everyone who had TC control to turn it OFF.
I had no trouble on any hill, TC on, Snow button on. :y
The V6 was far more stable than my old 2.2 that hadn't got TC.
« Last Edit: 19 December 2010, 07:55:31 by Auto_Addict »
I like red cars
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Traction Control
« Reply #1 on: 19 December 2010, 08:40:15 »
I find a mixture of having it on and off works best.  Sometimes the TC stops me from moving off, so TC off reverse and then forward.  Once moving agin TC back on, the only downside is that anyone behind you may get a bit of a spray  ;D
« Reply #2 on: 19 December 2010, 09:02:06 »
See you at the bottom of my street and see if you get up the hill in your Omega TC on or off. There's only so  much grip on compacted snow/ice  ;)
« Last Edit: 19 December 2010, 09:03:05 by Andy_B »
Debs.
« Reply #3 on: 19 December 2010, 09:47:11 »
My house is up on a hill on a rocky track with sharp-turns, dips and some quite steep-rises:
Without snow chains and TC on; the car rapidly loses momentum on the icy rises and will get stuck (esp. on the bends when the diff-torque favours a side).......
.....Without chains and with TC off; I can keep the momentum up and press on.
....with chains fitted it really doesn`t matter either way. ;)
« Reply #4 on: 19 December 2010, 09:57:14 »
Debs studded tires will do the job (++ this signs done by a cat ;D) and miggy will be more comfy on the steering and vibrations..
« Reply #5 on: 19 December 2010, 10:37:45 »
As good as studded tyres are cem, they are a waste of money in this country.
We had an SRI cavalier fitted with them at work on spare steel rims and it was found they were fantastic when the snow first fell if the wheels were fitted at work, once the tarmac was showing again the wheels need to be changed ASAP or the studs gring down in next to no time.
The ideal situation would be to have a pair of these in the car at all times, and all neccesry tools like and exhaust drin airbag/jack, quick lift and electric wrench to enable a quick pit/tyre swap.
Sadly that just wont work by the road side, plus weather predictions are poor and you may end up friving round for days on studded tyres based on a weather forecast that was wrong.
My local area (Netweather for example) forecast 96, 95, 92, 92, 86 and 83% of chance of snow  starting friday, friday there was a light dusting that came and but london had 3" and Debs got 2'.
So for me it would be my GLS on M+S tyres for winter and the Elite for the rest of the time, but swapping tyres to suit the weather is not allways possible.
« Reply #6 on: 19 December 2010, 10:55:52 »
agreed.. studded tires cause headache in city driving but Debs area definitely requires studs imo..
in the past I used studded tires and compared them with normal winter tires against steep icy hills ..
[exeggaration on] you can climb even a 90 degree icy hill with studs ;D ;D [exeggaration off]
seriously , many of my friends living in hilly areas prefer them and dont care about the vibration they cause on dry but I cant..
and putting them on and off (when required) under freezing cold and snow really not practical (I did as I kept 2 in the boot )  and causes all your dresses to be ruined :(
« Reply #7 on: 19 December 2010, 11:37:50 »
..... and causes all your dresses to be ruined :(
  :o  :o  :o I didn't think were the kind of man to wear dresses  ;)
I think you meant clothes. You get dressed into your clothes or generally women wear dresses.  :y  :y  :y
Dress is a word that can mean many things depending on how it's used.  ;)
http://www.google.co.uk/search?hl=en&source=hp&q=define%3Adress&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=  ;)
« Reply #8 on: 19 December 2010, 12:56:40 »
 :o   ;D     thanks :y
« Reply #9 on: 19 December 2010, 14:27:25 »
There was me thinking cem was a pretty boy ;D
(cem - a 'pretty boy' is a man who pays a little too much attention to his own looks, which can be summarised as GAY) :P
« Reply #10 on: 19 December 2010, 16:13:48 »
:D
 I just assumed cem was talking specifically about Debs!  :D
Debs.
« Reply #11 on: 19 December 2010, 16:53:27 »
As in:
"Which side does Sir, dress?"
"Oooh, suit you Sir!"
 ;D ;D ;D ;D
« Reply #12 on: 19 December 2010, 16:58:53 »
Had ESP & TC off in the Van and DSC and everything else off in the 535d when I had it on, I was stuck and couldn't move in either, had them back on, on the main roads though as it does stop you spinning  :)
« Reply #13 on: 19 December 2010, 18:29:29 »
As in:
 ;D ;D ;D ;D
Trust you to think of that meaning!  ;D ;D ;D
Page created in 0.012 seconds with 14 queries.
