Author Topic: Fridge - temp too high  (Read 920 times)
I_want_an_Omega
« on: 09 January 2011, 09:26:09 »
We have an old fridge, well, its 12 years and a Neff. The temp seems too warm on the coldest setting and its gradually been getting worse over the years - i.e. having to turn the down "down" to maintain a useful temp.
Its a built in single fridge with no freezer section if that helps.
Any fridge experts have any ideas?
Thanks - Rob
Richie London
  • heathrow
Re: Fridge - temp too high
« Reply #1 on: 09 January 2011, 09:47:18 »
maybe the fan at the back has clogged up with dust over the yrs and not drawing enough air in to cool it, just a thought. or maybe its passed its sell by date now.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #2 on: 09 January 2011, 09:48:12 »
It could be a number of reasons causing it to run to warm. Check the obvious "cheap fix" things first such as door seals closing properly, the compressor and condenser should be clean and free from dust etc. If it needs professional attention i.e re- gassing or a new stat, it may be more cost effective to replace it with a new one. If you can find a fridge repair person to have a look and give you a free estimate with no call out charge you can then make your mind up which way to go.
Richie London
  • heathrow
« Reply #3 on: 09 January 2011, 09:50:34 »
Thanks - Rob
also has the door seal gone letting cold air out
Taxi_Driver
« Reply #4 on: 09 January 2011, 10:42:38 »
Assuming its been fitted correctly.....with air vents fitted to allow air flow at the back of it...it sounds like the thermostat is failing. Quite an easy check.....does the compressor run all the time? If not, thermostat problem and probably easy to change.
« Reply #5 on: 09 January 2011, 11:03:51 »
Yah, sounds like the classis slow failure of the stat.
Easy enough to get replacement ones and fitting is not to hard.
It should be said that 12 years is quite a short life for a fridge but, I guess it is a Naff (form over function lol)
russ0205
  • northants
    • mondeo
« Reply #6 on: 09 January 2011, 11:12:27 »
Is it a frost free neff ???  if so look for blocked air flow as said, if old style listen is the motor running all the time ??
pm me if need rob i am an appliance engineer  :y
« Last Edit: 09 January 2011, 11:15:40 by russ0205 »
I_want_an_Omega
« Reply #7 on: 09 January 2011, 17:11:04 »
Thanks guys - will look during the week as have been out all day today
