Author Topic: Ccrt700 sim card  (Read 4679 times)
StuPot100
  • Bedford
  • The forum is better than any aa
Ccrt700 sim card
« on: 08 April 2010, 21:20:50 »
Do u have to use a special sim card in the ccrt700 or is it sim card straight from my phone
Welung666
Re: Ccrt700 sim card
« Reply #1 on: 08 April 2010, 21:22:22 »
It needs to be a full (credit card) sized card. I used a new card from O2 and threw the sim part out, slip ofe tape on the back and clip my normal sim into the hole :P
You managed to get a CCRT700 then?
« Last Edit: 08 April 2010, 21:24:11 by Welung666 »
« Reply #2 on: 08 April 2010, 21:24:03 »
No you cant i dont think, they are a different frequency range, someone will confirm later.  I just cant remeber  which one it is, plus I think you are limted on providers as well.
« Reply #3 on: 08 April 2010, 21:24:37 »
Forgot to add that bit.   :-[
Welung666
« Reply #4 on: 08 April 2010, 21:25:10 »
Correct, O2 or Vodafone only 900 and 1800 IIRC
« Reply #5 on: 08 April 2010, 21:28:47 »
to clarify, ccrt700 is 900Mhz only, which limits you to o2 & voda (but voda are on the shitlist now, as I'm sick of their BS).
Sixstring
  • Lydney, Gloucestershire
« Reply #6 on: 08 April 2010, 21:31:27 »
Might I add that Tesco, Fresh, and Lebara will NOT work, even though they roam on 1800mhz via the O2 network.
AND the 3G cards give issues with the CCRT700 too, causing "freeze"
Sorry to hyjack the thread, used to fit car kits for a living......
StuPot100
  • Bedford
« Reply #7 on: 08 April 2010, 21:32:20 »
Yes I did thanks got one from lincs Robert it's finished of the inside of the car a treat bloody marvelous this site
« Reply #8 on: 08 April 2010, 21:32:56 »
Certainly, Tesco works on 900Mhz (via O2), thus should work in ccrt700
STMO999
« Reply #9 on: 08 April 2010, 21:33:44 »
Had this on my alfa, would only work with vodaphone.
StuPot100
  • Bedford
« Reply #10 on: 08 April 2010, 21:36:38 »
I'm with o2 and rang them today for code and explained that it goes in a ccrt700 but didn't say I needed a credit card size sim where can I get 1
« Reply #11 on: 08 April 2010, 21:38:00 »
All SIMs are provided as CC size - for most phones you push the small bit out.
StuPot100
  • Bedford
« Reply #12 on: 08 April 2010, 21:38:06 »
I fitted cd and radio and picked me missus up and nearly blew her eardrums out lol
« Reply #13 on: 08 April 2010, 21:38:31 »
What what do they know about Vx head units? Just ask for a SIM, it will come fully size, just don't push it out.
« Reply #14 on: 08 April 2010, 21:39:29 »
If you did not replace the Bose speakers and wiring, it will blow the headunit, not kidding, literally blow ;)
Replacement headunit will be 4 Ohm, Bose is 2Ohm
Pages: [1] 2 3 4  All   Go Up
