Author Topic: MS Access Pivot tables  (Read 953 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 10 January 2011, 20:27:01 »
Back in my programmer days I spent a long time developing and debugging various Access applications and although I havent changed employer it looks as though I may be going back in to that as there is a potentially lifechanging opportunity on the horizon.
I have been told to look at pivot tables, I left the programming world just as they were added as a feature so I have yet to play with them.  They seem straightforward enough, but I am interested in your own experiences/problems.
The system I am looking at working on handles a huge amount of data and the current usage of various forms/tables could be condensed into one or two with a pivot table.  Sounds interesting but like I said...what do you think?
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: MS Access Pivot tables
« Reply #1 on: 10 January 2011, 21:04:37 »
I never knew Access could handle large amounts of data.  Especially if there were more than a few users sharing.
Has it improved?
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Gaffers
« Reply #2 on: 10 January 2011, 21:07:07 »
Has it improved?
Quite a lot, this system has several iterations all communicating with each other and the central DB all using data gather from 3 other sources either directly or through a datadump.  All of them work on different shared network drives too.  I remember when it would fall over if 3 people opened the same copy  ;D
« Reply #3 on: 10 January 2011, 21:20:54 »
can you define huge..
both oracle and sqlserver have special tools/commands/programming languages built in to handle those kind of jobs (like mdx).. olap, rolap etc..
unfortunately no idea about access :-/
Gaffers
« Reply #4 on: 10 January 2011, 21:28:01 »
Not so much as to cause Access a problem, but more than just your simple 2D table.
No way that we can upgrade to anything other than Access, finances and continued maintenance dictates
« Reply #5 on: 10 January 2011, 21:37:36 »
2 choices , if access can realy handle the data it has some pivot options
like this one http://www.blueclaw-db.com/accessquerysql/pivot_query.htm
or
back to conventional method of 3d ,4d... matrixes with some programming language..
Gaffers
« Reply #7 on: 10 January 2011, 21:50:07 »
or like this
http://msdn.microsoft.com/en-us/library/aa662945(v=office.11).aspx
Good find, that will help me :y
« Reply #8 on: 10 January 2011, 21:53:53 »
and I must state that I would prefer conventional matrix programming as it gives you total control over others , but being slower than  direct pivoting transact sql..( thats valid for mssql and oracle not tested on access..)
Sixstring
  • Lydney, Gloucestershire
« Reply #9 on: 11 January 2011, 15:59:11 »
Didn't know you were completely proficient in swahili mate.......
That is what you are speaking about???
pivots??
engineering??
Gaffers
« Reply #10 on: 11 January 2011, 18:08:03 »
me too, I would love nothing better than to slap a nice Oracle DB in there but I am very very restricted as to what products, even the version I can use
