Project TB2 - Update 12
Started by TheBoy, 16 May 2007, 20:44:38
Yesterday, on the way back from Omegatoys, I was late and in trouble with Mrs TheBoy for being late, so I was 'pressing on a bit' in the tractor. Came off a roundabout, foot hard to floor, revs went up, speed went down. Just like a slipping clutch.
So I thought I'd better stop, so started to brake, and drive came back for a while, when started to lose again.  Every time I braked firmly, I got drive back.
As I was near home - about 1/2m, I limped it home in 1st with no further dramas.  Absolutely stank of ATF about half and hour later...
Due to symptoms, esp seeming to get drive when braking (pushing ATF to TC), I suspected low atf level.
So tonight, jacked up one side, through in 1.5l via a hose and funnel with engine running.  Removed hose, and about 1l came out, possibly more (some made it on to drive).  So I'm guessing it wasn't that?
So, I guess I've knackered the box as well.
Well it was an AR25 and they don't last much beyond 120k anyway.... as for your 'pressing it a bit' in English for the rest of us, it means razzing fubar out of it  ;)
Anywho I shall be back in Brackley next week if you need any help  :y
QuoteWell it was an AR25 and they don't last much beyond 120k anyway.... as for your 'pressing it a bit' in English for the rest of us, it means razzing fubar out of it  ;)
Crawl inside my gearbox, and see why it let go... ;D
GO GO Gadget Hands....
Not sure I feel too well.  I think getting drunk, and stinking of ATF is having a funny effect  :-/
Auto Addict
I like red cars
QuoteNot sure I feel too well.  I think getting drunk, and stinking of ATF is having a funny effect  :-/
If its anything like diff oil, not nice!
You'd better not be ill when i get back, we got work to do on my senator:
Remove air-con condensor (which means taking the rad out), remove as much air-con junk as possible. replace oil cooler temp sensor, copper slip grease the wheels up, more coolant flushes.
Ohhh that reminds me, you managed to take a look at the Senny's cruise ECU?
Touched up some of the connections that looked suspect, but didn't do all as my solder seems strange - too much flux I reckon  :-/
Martin_1962
Remove air con :o
No it doesn't!
I know, I removed one at the top of a mountain in France!
3 hack saw cuts, loosen the rad mounts and yank!
Admin
'tis true....  ;D
Ideally you want to rig up the air con fans to a switch in the cabin for extra effective cooling, whiuch you will need at times!
The Administrator.
QuoteYou'd better not be ill when i get back, we got work to do on my senator:
Whens that? From now til mid June will be just the odd evening I'm afraid, no weekends, except this one.
But your removing a gearbox this weekend!
QuoteBut your removing a gearbox this weekend!
Only if I can source a replacement, and some volunteers!
Admin
Consider me volunteered, if I am capable!  :)
The Administrator.
