Author Topic: Sky Coax Cable?  (Read 995 times)
Sky Coax Cable?
« on: 01 February 2011, 13:59:06 »
On the original box the installed a single coax cable/
On the HD it is a dual core cable for the twin tuners.  During the summer it is my intention to have cables from the LNB added for both bedrooms and may end up fitting an Oct LNB as there will be Sky HD in one bed room and my dual tuner DVD recorder in the living room, then an input on each TV, then at least 1 computer TV card in the bedroom and maybe in the living room as well, and thats before the 2nd bedroom gets cabled up.
My question is, do they do 4 core coax that is suitable from the LNB for the Fresat and HD etc.  or even 6 or 8 core to allow for tidyness and flexibility.
TIA.   :y
Re: Sky Coax Cable?
« Reply #1 on: 01 February 2011, 14:40:06 »
I have seen 5 core satellite coax in the past but it was pretty big and ugly. I would just go with individual coax or shotgun twin cable, TBH.
This is the stuff. No longer stocked. ::)
http://www.dastv.co.uk/shop/Webro_WF100_x_5_Core_Coax_Cable_Per_Metre_284.php
You can reduce the wiring to the dish by using a quad output LNB into a switch that will give the required number of outputs in the house.
There are only ever 4 possible modes an LNB channel works in so a quad LNB followed by a switch to select the required configuration for each output still allows as much flexibility as an octal LNB. Probably a more expensive route, though as the switches tend to be disproportionately expensive.
Re: Sky Coax Cable?
« Reply #2 on: 01 February 2011, 15:14:57 »
I'll be doing the same shortly... Currently have a Quad LNB feeding the HD box in the lounge and the Sky+ box in the bedroom. Need another feed into the lounge as the TV has Freesat HD built in and it would be nice to have the ability to tune to a 3rd channel in the lounge when recording 2 programmes at the same time :y
Re: Sky Coax Cable?
« Reply #3 on: 01 February 2011, 15:41:20 »
Cheers Kevin  :y
So basically then, If I had a single cable to Living room, then the 2 bedrooms and then 1 to the kitchen.  I could then add a 6 way switch to the bedroom and have 1 x TV, 2 DVR feed, 2 HD Sky and 1 into a TV card in the computer.
Then a 4 way in the living room  1 x TV, 2 x DVR and 1 x MCE if I ever get round to building one.
Re: Sky Coax Cable?
« Reply #4 on: 01 February 2011, 15:41:39 »
I use one of these in the loft:
http://www.satcure.co.uk/tech/loftbox4.htm
Works very well!
Supports Sky plus in the lounge plus an additional 2 other sky outputs. Also distributes all RF signals to all outputs and supports remote eye control of sky boxes (and via an alternative system any IR device in the main room).
Requires only a single quality coax to all secondary rooms and a twin to the main room.
Simples!
Re: Sky Coax Cable?
« Reply #5 on: 01 February 2011, 18:25:35 »
Me thinks Mr watches too much TV...? :o
So nobody's too bothered about HD on 2nd  3rd any of their other tv's in the house?  :-?
Re: Sky Coax Cable?
« Reply #6 on: 01 February 2011, 18:41:06 »
Crazy thing is Chris I have hardly watched any TV in the last few weeks.
I just want any many possible options to record coz when there is something good on then 2 channels not enough, so if I have 2 x sky channels recording then I have multiple options regards freesat for non sky only channels.  Plus half the time I stumble on something  I can just click record, and it would be nice to be able to record the likes of top gear straight to a PC and be able to archieve only the bits I realy like.
Re: Sky Coax Cable?
« Reply #7 on: 01 February 2011, 19:25:14 »
You missed the 1st TV off the list as far as I'm concerned. ;)
Re: Sky Coax Cable?
« Reply #8 on: 01 February 2011, 20:50:13 »
Yeah you love it really, get your wallet out posh boy  ;D;)
Re: Sky Coax Cable?
« Reply #9 on: 01 February 2011, 22:53:39 »
Hmm. Now you mention it, I've always fancied a 405 line set. ;D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Sky Coax Cable?
« Reply #10 on: 02 February 2011, 11:27:38 »
What about using Sky Anytime?
Page created in 0.035 seconds with 16 queries.
