Author Topic: Back Pain - Dilemma  (Read 2443 times)
Back Pain - Dilemma
« on: 06 February 2011, 15:37:38 »
As most of you know, I've had severe back problems for a couple of months. Seemed to be much better and returned to work this week on restricted hours. Here's the dilemma...
I haven't had to do a full driving stint yet but, after my 2nd shift last night, I have sciatic pain again :'( :'(
Not as debilitating as it was but very uncomfortable. SWMBO thinks I should call in sick again tonight, I plan to go in (as it's only a 6 hour shift) but make an appointment to see the company quack again next week as there's no way I'm fit for 12 hour shifts yet. Any thoughts?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Back Pain - Dilemma
« Reply #1 on: 06 February 2011, 15:44:41 »
Take it slowly and talk to the quack about the pains you're getting is the best plan, Rome wasn't built in a day Paul.
TuBy's new whipping boy.
« Reply #2 on: 06 February 2011, 16:14:00 »
I intend to... The dilemma is whether I go in tonight :-/ :-/
Don't really want to call in sick again but concerned I might do myself more damage :'(
« Reply #3 on: 06 February 2011, 16:16:36 »
That sounds very sensible LD :y :y :y
However make sure that during your job you do not place any unnecessary strain on your back if that is possible.  If you find tonight that the pain increases, then I personally would cease work immediately and report sick.  It is all too easy to make a back complaint a lot worse by pushing yourself too hard too quickly.
Take great care with yourself LD ;) ;) ;)
« Last Edit: 06 February 2011, 16:17:29 by Lizzie_Zoom »
Omegatoy
  • UK
« Reply #4 on: 06 February 2011, 16:34:59 »
are you positive its sciatic pain? if yes then get your self to an accupunturist, when i had it i couldnt move as the pain was excrutiating, an hour session for the next 3 days and i was back at work!!! make sure they are a good one though, ask around to se which one gets good reports,
I was amazed they actually put needles in my wrists neck and spine and in twenty mns i could feel the pain subsiding!! :y
« Reply #5 on: 06 February 2011, 17:03:45 »
if it was fine until you drove, are you sure its not the truck seat? I can drive be a passenger in the Omega all day long without issue, 20 mins through London in a Addison Lee VW People carrier and I had back pain!
Danny
  • Wigan, Greater Manchester
« Reply #6 on: 06 February 2011, 17:09:13 »
I would suggest doing what you suggested in the opening post, unless you wake up in more serious pain
welcome to the forum ;D
« Reply #7 on: 06 February 2011, 17:18:41 »
I hear good things about these. :y
I tried an osteopath. A complete waste of time and money in my opinion. :-/ :-/ :-/
Get well soon LD... :y
« Reply #8 on: 06 February 2011, 17:32:50 »
Yep... I've been going through it for the last 9 weeks! Started as a "Slipped Disk" and progressed through "Lumbar Facet Syndrome" (one caused the other) with sciatic pain and all sorts. Been seeing a chiropractor for 8 weeks who is also a registered Acupuncturist and it worked wonders. Trouble is, it's Sunday and I'm due into work in 2 hours. ::)
I work 65  feet (or so) up a crane and bent over!
Just spoken to my Chiropractor (he's also a mate!) and he's suggested giving it a go but not pushing too far... He also commented that he thought I'd be off longer than I have been already from previous experience. :o
« Reply #9 on: 06 February 2011, 17:34:14 »
Not a truck Tunnie (as you know!), a crane ;)
Driving position is leaning forwards to stare down through your feet ;)
Martin_1962
« Reply #10 on: 06 February 2011, 17:35:38 »
Mine is 95% back to normal.
Just a bit sore if I stand a lot.
Currentyly have some other issues which need to be sorted but I am having constant headaches and will be seeing a doctor tomorrow.
shane1000
  • derby
  • studied nothing for 35yrs so now an expert on it
« Reply #11 on: 06 February 2011, 18:13:24 »
are you sure its sciatic and not disc trouble? a general xray set up through your gp should show any disc trouble... either ware and tear or degeneration.  if its degeneration it could be caused through your job and you will be entitled to an INDUSTRIAL INJURIES  payout. so well worth investigating... :y
« Reply #12 on: 06 February 2011, 18:17:51 »
I could not remember which way around it was, if you were in recovery now, or crane  :-[ Apologies  :-[
Makes sense now, try acupuncturist as a few have suggested, father T has had it few times works well i hear.    :y
Taxi_Driver
« Reply #13 on: 06 February 2011, 18:31:52 »
Sciatic is caused by a disc, a disc moves and presses on the sciatic nerve, causing pain normally down the back of the leg.
I've lost count on how many times I've slipped a disc....last one was 3 weeks ago.....thankfully after 2 weeks it went back in on its own and its fine again now.....tho having a hot as i could stand jacuzzi bath every evening for 1/2hr or so, probably helped it  :y
My doctor is of the type, that just prescribes 'industrial' strength painkillers and tells you to carry as normal... :-/
Taxi_Driver
« Reply #14 on: 06 February 2011, 18:37:37 »
Thats a toughie really.....i assume you have to climb a very tall ladder to get to the cab....thing is...if your back got worse in the cab....would you be able to descend the ladder  :-/
Bit different if mine goes in my bus....i can slowly just fall out of it  ;D
