Author Topic: Computer help Please - System file missing.  (Read 1533 times)
Zipper
« on: 16 February 2011, 10:51:23 »
My girlfriends PC hung last night whilst installing some Samsung phone software (The disk that came with the Tocco lite to sync it with the computer.)
Tried a 2nd time and it seemed to work, then had to reboot and got following error message on screen.
WINDOWS COULD NOT START BECAUSE THE FOLLOWING WAS MISSING OR CORRUPT.
<WINDOWS ROOT>\SYSTEM32\HAL.DLL
PLEASE INSTALL A COPY OF THE ABOVE FILE
Now is this a windows or a samung file, and how would I/we go about putting the problem right.  #
Thankyou  :y
Re: Computer help Please - System file missing.
« Reply #1 on: 16 February 2011, 10:58:53 »
Do a System Restore to the nearest point before the phone software install :y
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #2 on: 16 February 2011, 11:11:40 »
You haven't left the software CD in the drive by any chance?  Could be trying to boot from it?
Check your boot order in the BIOS to ensure it's using HDD to boot from first.
If really lost or missing HALL.DLL then use XP install disc to replace system files.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Zipper
« Reply #3 on: 16 February 2011, 11:19:11 »
Cant get/boot into windows to do that.  :-/
Zipper
« Reply #4 on: 16 February 2011, 11:23:39 »
You haven't left the software CD in the drive by any chance?  Yes.
 Could be trying to boot from it? Removed it
Check your boot order in the BIOS to ensure it's using HDD to boot from first. Tried that as well
If really lost or missing HALL.DLL then use XP install disc to replace system files. Looks like being the final option, but bit reluctant to do so at this point as she needs to retrieve some info from an MSM chat history file. (Unless the drive can be slaved and wecan locate and read where the chat history is stored)
djac
  • West Sussex
    • 2001/Y Omega 3.2 Elite
Chris_H
  • E London/Essex UK
« Reply #6 on: 16 February 2011, 16:26:30 »
I would hardly classify an MSM chat history file as a system file.
There should be a Recover option when doing an install that allows just System Files to be replaced.  You might have to re-patch afterwards to get back to current (in)security levels.
Zipper
« Reply #7 on: 16 February 2011, 17:22:25 »
Been having a play and try as I might I hoped to get to the root DIR with the view just to copy the missing .DLL file across from another hard disk.  This idea failed in the fact that as soon as I pressed a key to try anything the PC just rebooted.
Tried a windows CD, but the repair option hasn't come up so am starting to bang my head against a brick wall  :-/
Chris_H
  • E London/Essex UK
« Reply #8 on: 16 February 2011, 17:39:39 »
You might have to press F8 early in the boot process to get the Windows CD to offer Restore options.
toxic34
  • Hartlepool
« Reply #9 on: 16 February 2011, 17:43:47 »
Have you tried booting the puter into Safe Mode?
As your puter is starting keep pressing F8 then choose
to boot into Safe Mode. :)
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #10 on: 16 February 2011, 20:38:21 »
normally the original windows disc will have a repair option.
the F8 option works as well to start up in dos/command prompt
where are you living there might be someone nearby on here who could help out :y
