Author Topic: decorating question (help)  (Read 1710 times)
mantagte
  • great yarmouth
    • omega bmw maverick
« on: 19 February 2011, 21:25:02 »
am slowly decorating  the downstairs but i have a problem (little one)
three weeks ago i rubbed down the door and framework then cleaned with sugar soap rinsed etc
paint went on fine no problems
 today painted the skirting in the hallway
lovely brilliant white
But on the frame and the door the paint has gone a creamy colour (wtf) have i done wrong :question
non smoking house
Re: decorating question (help)
« Reply #1 on: 19 February 2011, 21:27:48 »
seems like some chemical interaction/reaction between the previous cleaning substances and the paint :-/
SJKOO01
« Reply #2 on: 19 February 2011, 21:31:42 »
Mangate,
Not sure if this link will be of any help to you, but maybe a starting point  :y
http://www.diydata.com/decorating/painting-doors/paint-preparation.php
bluey
  • West Mids
« Reply #3 on: 20 February 2011, 01:01:07 »
Stick another coat on, white is pretty transluscent and if you didn't have a solid white undercoat underneath then you'll need more than one layer to get it looking right.
V6 CDX-er
  • Sheffield
« Reply #4 on: 20 February 2011, 01:13:29 »
This I reckon ^^^^^^^
Perhaps give it a light key first, then another couple of top coats?
Bent valve
« Reply #5 on: 20 February 2011, 09:28:47 »
Sometimes, using oil based gloss paints directly on top of old gloss finishes can cause the previous coat to bleed through.
You can avoid this by using water based gloss, I use it for that reason, and the fact that it gives a more satin like finsh than traditional gloss.
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #6 on: 20 February 2011, 10:56:06 »
Speaking as a painter and decorator since the mid sixties....
Why did you sand it down??? ;D ;D ;D ;D ;D ;
Seriously.....how far back did you sand it, was there varnish underneath, did you clean off the sugar soap.
 Picking up on another reply...water based paints will allow bleed to a much higher degree than oil based. It is not common for the trade to use water based paint on woodwork. :y
If you need to seal the stain, a product I use is B-I-N Sealer.
There are other products about but a lot are only sold in 5ltr tins.
B-I-N sealer will seal nicotine, crayon, water stain, graffitti, etc etc.
A small tin will cost about £12 to £15 pound. Be very carefull how you use it as it is VERY liquid, stinks (shellac based) and sticks like Sh1t to a blanket. :y
Just looked in my van and I have a product called Zinsser Cover stain....this is as good as B-I-N...dries in 30 mins, covers the world and his wife, can be used on any surface, behaves like normal undercoat, use it as normal undercoat.
The tin size I have is 2.5ltr. It won't be cheap, but I can assure you its brilliant......it can be colour tinted also. :y
Going back to my first statement....this Cover Stain does not need gloss surfaces to be sanded !!!!!!!!! :y
Hope this helps ;)
http://www.decoratingdirect.co.uk/techdata/z/ZINCS/
« Last Edit: 20 February 2011, 11:10:03 by terbert1 »
Bent valve
« Reply #7 on: 20 February 2011, 19:10:44 »
Hope this helps ;)
Agreed, but waterbased paint does not cause bleed through like oilbased paint will on previously oilpainted surfaces.
Richie London
  • heathrow
« Reply #8 on: 21 February 2011, 08:35:37 »
2 undercoat.  1 good topcoat. good brand paint like johnsons or dulux trade
bluey
  • West Mids
« Reply #9 on: 21 February 2011, 11:25:15 »
I use Dulux Trade, without a decent solid undercoat it's no better than cheap own brand stuff but it does take longer to lose its original pigment.  And I use rollers, not brushes - more even coverage with no sagging and drips.  :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #10 on: 21 February 2011, 17:53:50 »
i use dulux one coat gloss. i realise im gonna get a load of people say this is rubbish buuut used correctly is great on sanded wood.
RIP Paul Lovejoy
