Author Topic: Anyone here use Eudora?  (Read 616 times)
Nickbat
« on: 31 March 2011, 11:25:15 »
I've been using it for years without a problem. I now have a Samsung notebook with a 3 Network dongle. I have loaded Eudora on it and can receive mail, but it always fails to send, with the following message:
"Error getting network address for "xxxx.xxxx.com". cause: requested entry not found (11004)."
I have cross-checked the setup for sending mail with my desktop and they are exactly the same. Seems to me as if the 3 Network can't find the outgoing SMTP server, but haven't a clue why.
I have scoured the web for solutions, but with no luck.  :(
Anyone on here got some advice? :-?
« Last Edit: 31 March 2011, 11:25:30 by Nickbat »
Re: Anyone here use Eudora?
« Reply #1 on: 31 March 2011, 11:33:59 »
Thast because your outgoing email server needs to be set to the Three one.
The Three SMTP server is usualy:
Server: smtp-mbb.three.co.uk
Encryption: None
Server port: 25
Nickbat
« Reply #2 on: 31 March 2011, 12:30:40 »
Encryption: None
Server port: 25
No joy, Mark, but thanks anyway. :(  :y
Nickbat
« Reply #3 on: 31 March 2011, 12:45:18 »
Cracked it: Change outgoing port to 587 and uncheck the authentification box. :y :y
Mysteryman
« Reply #4 on: 31 March 2011, 13:06:43 »
I was just about to tell you to try that. ::)
« Reply #5 on: 31 March 2011, 13:24:18 »
Most networks with DHCP users will block outgoing port 25 (or redirect to their own SMTP servers) for those DHCP ranges to stop those IPs getting blacklisted, as its a PITA and rather expensive for a company to unblacklist an IP.
The likes of Spamhaus demand a $300 'donation' for companies to remove an IP from their blacklists...  ...and they are just 1 blacklist provider ;)
Using alternative ports will allow you to access your own SMTP server, though invariably, if you are coming from a foreign network, it will require authentication.
« Last Edit: 31 March 2011, 13:24:56 by TheBoy »
