Pages: [1] 2 3  All   Go Down
Author Topic: Range Rover LPG  (Read 3264 times)
Range Rover LPG
« on: 07 May 2011, 17:41:47 »
What would be involved in LPG'ing one?
It would be a 2002 (newer shape) with the 4.4 BMW V8 lump, I assume tank(s) would be underslug at the back? With a smaller petrol tank installed?
What size would fit, is there room for 2x 80L?  :-/
Also no idea how easy it would be to drill the inlet manifold on the BMW lump, easy/hard?  :-/
Can you get away with a single varporiser or would two definetly be required?
Re: Range Rover LPG
« Reply #1 on: 07 May 2011, 17:51:21 »
The same as converting any car ;) ;)
Fairly sure there are vaporisers capable of supplying the fuel to run with a single unit.
Tank wise, think it's generally a 80/95L toroidal and small petrol tank... May be able to get a couple of cylinders in but doubt it'd be bigger than 60L each.
Manifold... Anything's possible ;) Take it off and it's fine I'm sure ;)
Google RPi Engineering... They know RR V8's :y
Oh... And budget about 4-5 times what you spent doing your 4 pot :o :o
Re: Range Rover LPG
« Reply #2 on: 07 May 2011, 17:56:52 »
£2k even DIY?  :o :o
Hummm thats more than I was expecting  :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Range Rover LPG
« Reply #3 on: 07 May 2011, 18:14:42 »
Give Teilo a ring   :y
Re: Range Rover LPG
« Reply #4 on: 07 May 2011, 18:23:13 »
£2k even DIY?  :o :o
At least, particularly if you want to go down the custom petrol tank route ;) ;)
If you just fitted a toroidal in the wheel well and kept the standard tank it's considerably cheaper ;) ;)
But whatever you do, make sure you research the kit properly as those BMW V8's can give variable results when LPG'd, sometimes being more expensive to run than on petrol :o :o It can be done very well, but research is the key :y :y
Give Teilo a ring
Yeah, why not. I'm sure the Stag 300 Premium is up to the job, as long as he can get hold of the other required bits. But make sure there's someone, somewhere who has managed to get one running right on it first :y :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Range Rover LPG
« Reply #5 on: 07 May 2011, 18:24:39 »
I'm considering tackling an XJR (straight six) later on this year once I have learnt from getting as many parts fo my install done by others fitting it myself so a RR install would be interesting reading for me  :y
Re: Range Rover LPG
« Reply #6 on: 07 May 2011, 18:26:51 »
Cheers Chaps  :y
Its only a consideration at the moment, thats if we even get one.
If we went donut tank in the wheel well and a "standard" install, would we be talking sub £1k?
Not sure how many people have run stag on 4.4 V8  :(  :-/
Re: Range Rover LPG
« Reply #7 on: 07 May 2011, 18:33:40 »
Cheers Chaps  :y
Well, given that a bog standard V6 install is about 700 once you've covered all the sundries, adding a doughnut tank (a 4 hole one. No point in messing about with a multivalve), an extra pair of injectors, uprated vapouriser and a V8 ecu kit with the extra loom connections, etc. I'd say that would take you over 1k before you go much further.
Re: Range Rover LPG
« Reply #8 on: 07 May 2011, 18:35:46 »
Cheers Chaps  :y
Cheers, guess given they at best get 15-20mpg the £££ saving would be fairly high, so repayment not a real issue.
Re: Range Rover LPG
« Reply #9 on: 07 May 2011, 18:39:25 »
Cheers Chaps  :y
I doubt it would be sub £1k (but probably sub £1.5k) and I would budget at a saving of 10ppmile like the V6's ;)
Of course, if it's going to be used around town all the time then it's not going to be as good (lots of cold running etc)
Re: Range Rover LPG
« Reply #10 on: 07 May 2011, 18:42:54 »
if we kept it, 95% motorway runs  :y
Re: Range Rover LPG
« Reply #11 on: 07 May 2011, 18:49:13 »
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
Re: Range Rover LPG
« Reply #12 on: 07 May 2011, 18:51:01 »
Try these
Good write up on full fat range rover forum
http://www.professautogas.co.uk/index.html
Previous
Omega 2.5 GLS Auto Estate         S115 JVV
Omega 3.0 Elite  Auto Estate        T639 TFA
Re: Range Rover LPG
« Reply #13 on: 07 May 2011, 18:57:17 »
Have a read through this site ;) ;)
http://www.v8dualfuel.com/lpg_kits/range_rover_L322_super.html
Looks tidy, but 2002 year is not the Jag Supercharged 4.2, but standard 4.4 BMW lump  :y
Re: Range Rover LPG
« Reply #14 on: 07 May 2011, 18:59:00 »
Try these
Those prices are quite competitve, especially for 8 pots  :)
Pages: [1] 2 3  All   Go Up
