Author Topic: Chicken Drumstick?  (Read 3605 times)
Bixy1
  • Leeds. West Yorks.
  • Hanging by a thread . . .
    • Diesel Vectra eventually.
    • Cats Tails
Chicken Drumstick?
« on: 16 May 2011, 16:29:22 »
Ok, easy question here, A cooked and nibbled chicken drumstick, if dropped into water, does it float or sink?  :-/
Its detached from the chicken naturally!  :-?
Cats Tails (The Adventures of Rommy and Reemy)
http://sbpra.com/derektmorgan
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Chicken Drumstick?
« Reply #1 on: 16 May 2011, 16:36:08 »
A bit of a random question, without trying it (and wasting a perfectly good chicken drumstick) I would not want to speculate
Bixy1
    • Cats Tails
« Reply #2 on: 16 May 2011, 17:01:44 »
I'm researching..... ::)
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #3 on: 16 May 2011, 17:05:35 »
I'll let you know after my next bbq! ;)
Bent valve
« Reply #4 on: 16 May 2011, 17:06:48 »
I think a cooked one would float.
Bixy1
    • Cats Tails
« Reply #5 on: 16 May 2011, 17:36:00 »
Thanks, that might be a while then judging by the present weather..!  ;D
« Reply #6 on: 16 May 2011, 17:41:56 »
You said 'nibbled' - depends how nibbled and how much meat there is vs. bone I would imagine.
There's only one accurate answer without knowing the weight and volume of the object and that is - does it displace a greater weight (volume) of water than it's weight?
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #7 on: 16 May 2011, 17:45:06 »
Seawater or fresh water?
Also how large is the drumstick? small, std or lge?
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #8 on: 16 May 2011, 17:50:44 »
depends on the water content and the bone density and how badly its been cooked. if its done by my dad on the bbq then it will float as its mainly carbon :D ;D
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #9 on: 16 May 2011, 17:52:44 »
Float
Phil H.
  • stamford lincs
« Reply #10 on: 16 May 2011, 18:05:32 »
Fresh chicken or thawed cooked from frozen ? any coating -breadcrumbs, batter ?
Varche
    • Golf Estate
« Reply #11 on: 16 May 2011, 18:39:16 »
Good question as I am sure I read somewhere that freezing affects the molecular density of bones and marrow. :y
hercules
  • sunnyudders
« Reply #12 on: 16 May 2011, 18:53:39 »
how far above sea level are you and is the said drum stick from iceland or a farm shop,i would also be interested in if the drum stick is coated in a marinade of some sort and the type of marinade and from which manufacturer including the amount used per drum stick and please could you state which fuel was used to cook the drum stick,if lpg was it butane or propane and which size bottle or was it charcoal or possible electric,please state if the oven used was fan assisted or not.untill you give us all the information i am not passing verdict on the said matter as i dont want to be held legally responsible for any outcome :y
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #13 on: 16 May 2011, 18:59:29 »
i say it would SINK!!! well did it, put me out my misery??  ;D ;D :D
smithpa7
« Reply #14 on: 16 May 2011, 20:14:08 »
Our chicken drumstick sank when dropped into Loch Tay last month :o :o ;D ;D
« Last Edit: 16 May 2011, 20:14:47 by smithpa7 »
Page created in 0.012 seconds with 14 queries.
