Author Topic: WiFi Woes  (Read 1721 times)
Martian
WiFi Woes
« on: 29 May 2011, 18:03:18 »
Our neighbours either side seem to be suffering random issues with their wi-fi since they didn't want to listen to advice about channel spacing.
I'm not too sure what is causing the interference for them, but it wouldn't surprise me if the source of the "interference" was using 2 of these, in conjunction with 2 these to get an ERP of just over 150W to improve their wi-fi signal throughout the house  ;D ;D
On the plus side, the kids now get 100% signal strength on their Xbox's which means they don't get killed before they have respawned on their own screen, which means they don't give me grief over the net being "laggy"  :)
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: WiFi Woes
« Reply #1 on: 29 May 2011, 18:43:06 »
I used inSSIDer and moved mine to a channel that no neighbours were using
Martian
Re: WiFi Woes
« Reply #2 on: 29 May 2011, 19:04:42 »
I didn't have that choice unfortunately as I (or rather the kids upstairs) were getting swamped because various neighbours were using the default channel for their ISP supplied routers.
It could have worked for all of us if everyone was prepared to collaborate, but 2 of the neighbours weren't interested in the easiest solution - kind of ironic that the same 2 are the ones who are getting issues because their signal is getting wiped out  ;D
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
Re: WiFi Woes
« Reply #3 on: 29 May 2011, 19:53:54 »
I keep losing the signal on my BT homehub, is there anything I can do about it?
Plomien
  • Swansea
Re: WiFi Woes
« Reply #4 on: 29 May 2011, 20:18:53 »
it depends on a number of different things
Download Inssider and see if you are getting cross interference from your neighbours. If it is still an issue without cross interference then it could be a duff router and worth contacting BT
jonnycool
Re: WiFi Woes
« Reply #5 on: 29 May 2011, 20:20:48 »
I'll try that, ta
Ken T
  • Stockport
Re: WiFi Woes
« Reply #6 on: 29 May 2011, 20:39:17 »
I wonder if a lot of wifi problems are down to modern homes being built with concrete blocks, that are cured (or something ) with aluminium spray, which is slightly conductive, so gives a faraday cage shield. In our house you can pick up the signal anywhere in the original part, but very badly/not at all in the extension.
Ken
I_want_an_Omega
Re: WiFi Woes
« Reply #7 on: 29 May 2011, 20:45:19 »
Thats a pretty cool bit of software isn't it?
I've just noticed that 2 "public" networks have massive signals - BTFON and BTOPENZONE.
Any idea what these are?
Omegatoy
  • UK
Re: WiFi Woes
« Reply #8 on: 29 May 2011, 20:54:14 »
we use the first one here and its brilliant we pick up the signal from around 100meters away so we can use the net, but we recently found that using it plugged nto a usb hub really interfered with the signal strength geting through to the computer!!! maybe they are the same?
Plomien
  • Swansea
Re: WiFi Woes
« Reply #9 on: 29 May 2011, 21:27:10 »
I believe they are types of BT home sharing networks
http://www.btfon.com/
http://www.btopenzone.com/
Re: WiFi Woes
« Reply #10 on: 29 May 2011, 21:52:19 »
They are indeed - I use them to OOF when on the Windows 'Phone.
I'm led to believe that it doesn't cost me anything as the WiFi access is also part of the Infinity service that I have.
Using these points also makes the data exchange faster than by just using the 'phone.
Martian
Re: WiFi Woes
« Reply #11 on: 30 May 2011, 08:13:01 »
Ken
Any type of obstruction (including a human) will have a serious impact on signal strength/quality. Cheapest solution if you want to remain wireless is a range extender.
At my local yesterday enjoying the sunshine & a BBQ and I decided to do a quick sweep of what wi-fi spots were available.
Our local is only 50 yards or so "as the crow flies" from our house, but there is a hill and houses blocking the direct "line of sight" path so plenty of obstacles to kill the signal.
My access point came up in the list, and still managed a respectable -58dBm for signal strength  :o
Actually I've just had a thought.
The radiotherapy has to be somewhere around the 2.4GHz band, I wonder if I could just stick one of the antennas up my backside for 10 mins a day instead of having to drive to Guildford 5 days a week to get it nuked  ;D
« Last Edit: 30 May 2011, 08:14:11 by Martian »
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: WiFi Woes
« Reply #12 on: 30 May 2011, 08:31:56 »
Hmmm such a willingness to put things up your arse.......: careful or DLK will break from his hols and pay you a visit lol
No chance of a decent signal with a sky router, I'm sat in the living room and I have to wave the mobile phone around to get WiFi signal.  I have a d-link in the garage but can't be added switching them
« Last Edit: 30 May 2011, 08:34:11 by mrgaffney »
Martian
Re: WiFi Woes
« Reply #13 on: 30 May 2011, 08:36:47 »
I'm quite comfortable with my sexuality, so no problem  ;D ;D
No chance of a decent signal with a sky router, I'm sat in the living room and I have to wave the recount phone around to get WiFi signal.  I have a d-link in the garage but can't be added switching them
Is your router the one with the detachable antenna?
If so, swapping it out for one of these will give you an ERP of around 1W instead of the paltry 200mW allowed.
« Last Edit: 30 May 2011, 08:41:26 by Martian »
Gaffers
Re: WiFi Woes
« Reply #14 on: 30 May 2011, 08:41:01 »
Nah, no antenna which is prob why it blows!
