Pages: 1 [2] 3  All   Go Down
Author Topic: fitting upvc door frame  (Read 14123 times)
Nickbat
Re: fitting upvc door frame
« Reply #15 on: 01 June 2011, 22:34:53 »
Hi Handy,
As Rob G says, whereabouts are you?
Please fill in your location in your profile. You'd be surprised how many members local to you would help you out with any problems. I speak from experience!  :y
Ken T
  • Stockport
« Reply #16 on: 01 June 2011, 22:35:02 »
I used a rawlplug type thing specially for fitting UPVC windows.
http://www.screwfix.com/p/window-anchor-8-x-100mm-pack-of-10/16018
basically drill a hole straight thro the frame and into the brick, put in the fixing, a light hammer in, a last turn on the screw to tighten and jobs a good 'un. A quick seal with sealant helps if the brickwork is uneven and keeps it water tight. The idea of using wood to pack out is good, give it a good coat of paint first. Pressure treated is a good idea, lots of timber merchants have it.
Its so easy to do, makes you wonder why they charge so much to fit windows  ::) ::) ::)
Ken
Vast majority of "proper" window fitters won`t touch those with a barge pole :P :P
Why ?.
Ken
« Reply #17 on: 01 June 2011, 22:36:55 »
was going to buy these
http://www.screwfix.com/p/frame-fixing-7-5-x-122mm-pack-of-100/81227
That`s the ones. You need a fix 150mm from corners then at app. 3-350mm centres
handy
« Reply #18 on: 01 June 2011, 22:40:13 »
Cardiff here :)
« Reply #19 on: 01 June 2011, 22:42:19 »
Ken
Why ?.
Ken
If at a later date the door or window needs to be removed for whatever reason, it`s far easier to remove a torx fixing than the sleeved fixings. Reason being, the screw in the plastic sleeve is soft metal and invariably the pozi head will mash up and secondly you will rarely pull the plug from the wall. If you manage to get the screw out you will still have to cut through the plastic sleeve that is stuck in the frame and half in the wall.  :)
« Reply #20 on: 01 June 2011, 22:43:33 »
Cardiff here :)
Bit too far for me. Once the door is fixed, let`s hope it doesn`t need "toe & heeling" ;)
« Reply #21 on: 01 June 2011, 22:44:48 »
I like a bit of Heavy Duty  Rob  ;D ;D ;D ;D
And instant stick with the old superglue ::) ::) ::)
What are you bloody fitting with an 11mm torx :o ;D
« Reply #22 on: 01 June 2011, 22:47:31 »
Cardiff here :)
Is that the adjustment of the 3 hinges? Mine is doing my head in, to the point that I was going to fix the top and bottom locking bits with an angle grinder...... ::) ::) ::)
Ken T
  • Stockport
« Reply #23 on: 01 June 2011, 22:47:33 »
Ken
Why ?.
Ken
Aha, thanks for thanks for the explanation.
Cheers Ken
handy
« Reply #24 on: 01 June 2011, 22:49:58 »
Cardiff here :)
say what??
« Reply #25 on: 01 June 2011, 22:51:46 »
Cardiff here :)
What style of door Vamps, half glass/midrail/reinf. panel below or has it got a full height "feature panel" :question
« Reply #26 on: 01 June 2011, 22:54:58 »
Cardiff here :)
Is it as bad as trying to get a kitchen cabinet door to close properly? I hate that job..
« Reply #27 on: 01 June 2011, 22:55:57 »
Cardiff here :)
Half glass 2 tall leaded / decorative panes and a panelled bottom half. Problem is when you have to push the handle up to lock, very difficult, have had a few goes at adjusting it..... ::) ::) :-[ :-[
« Reply #28 on: 01 June 2011, 22:57:14 »
Cardiff here :)
[/highlight]
Much much worse...... :'( :'( :'(
« Reply #29 on: 01 June 2011, 22:57:16 »
Cardiff here :)
Both easy 8-)
Toe & heeling? read this. http://www.windowsanddoors.co.uk/estimate/windowsanddoorsinstallation.html
Pages: 1 [2] 3  All   Go Up
Page created in 0.023 seconds with 16 queries.
