Pages: [1] 2 3  All   Go Down
Author Topic: OOF down  (Read 3254 times)
OOF down
« on: 02 June 2011, 09:29:28 »
Temporary bodge implemented until I can kick the living daylights out of it fix it...
Martian
Re: OOF down
« Reply #1 on: 02 June 2011, 11:27:55 »
I'm having to use a proxy to access here at the moment, so pull your bloody finger out  ;D ;D
TheDaddy
  • Milton Keynes
Re: OOF down
« Reply #2 on: 02 June 2011, 12:12:15 »
TheBoy is waiting for DNS to propagate.
Re: OOF down
« Reply #3 on: 02 June 2011, 13:31:54 »
up and down like noones business here....
quick hosts file entry and its solid as a rock  :y
Re: OOF down
« Reply #4 on: 02 June 2011, 13:54:32 »
Be aware its currently on a dynamic IP if using hosts file.  Whilst DNS is proporgating, hosts may work well, but remember to remove it later else you'll lose access.
Re: OOF down
« Reply #5 on: 02 June 2011, 13:57:57 »
aye, no worries, as soon as i lose access, ill remove / change it  :y
Re: OOF down
« Reply #6 on: 02 June 2011, 14:23:29 »
This problem is also the cause of the current performance issue, and envisaged to remain far from peak performance for a couple of days.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: OOF down
« Reply #7 on: 02 June 2011, 18:48:12 »
Its been off all day for me,bloody gutted,had to do some work to pass the time :D ;D
other rides
Re: OOF down
« Reply #8 on: 02 June 2011, 19:26:57 »
Right, as part of the prework to get it all back to normal, we've had to implement some somewhat complex routing, which did cause a bit of an issue for the past hour. This is resolved, so we'll start, slowly, winding back to correct setup this evening, but it will take a couple of days for everything to sort itself out - much of what will happen once we kick off this process later this evening is out of our hands, its just the way the Internet works.
Sorry for any inconvenience.
Debs.
Re: OOF down
« Reply #9 on: 02 June 2011, 19:31:24 »
::) I`ve discovered that I can`t stand my own company, after today`s dearth of OOF! ;D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: OOF down
« Reply #10 on: 02 June 2011, 19:42:59 »
I reckon it was DLK! Even though he's away on holiday I bet he is still to blame
Re: OOF down
« Reply #11 on: 02 June 2011, 19:47:21 »
 ;D ;D ;D ;D ;D
I'm the same as Henry, I had to go outside & work on my car.
Re: OOF down
« Reply #12 on: 02 June 2011, 19:49:08 »
Those who messed with their hosts file really ought to consider testing without that mod now...
Re: OOF down
« Reply #13 on: 02 June 2011, 19:49:40 »
today I could ping but cant reach.. cant use proxies from job.. when home tried proxies it worked.. now back to normal..
Re: OOF down
« Reply #14 on: 02 June 2011, 19:53:52 »
It had to be rerouted via a different IP, and via a NAT device temporarily, and on a dynamic IP.
We have started the process of unravalling this mess the temporary fix caused...
Pages: [1] 2 3  All   Go Up
Page created in 0.062 seconds with 20 queries.
