Author Topic: Body Panels  (Read 1110 times)
Captain Slower
  • Reading, Berkshire
Body Panels
« on: 25 May 2011, 23:53:11 »
Evening, late I know, but does anyone know of a vauxhall breakers or such locoated in the southeast area? Had a small disagreement with a bollard this evening. Rear bumper is pushed in and the tailgate is creased and jammed shut.  :'(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Body Panels
« Reply #1 on: 26 May 2011, 07:22:53 »
This might be better in the General Car Discussion area  :-/
Re: Body Panels
« Reply #2 on: 26 May 2011, 08:02:50 »
Omega specialist breaker in Heathrow? Prolific on eBay last I looked
Re: Body Panels
« Reply #3 on: 26 May 2011, 14:11:44 »
Indeed. omegaspareparts. Run by an amiable chap called Steve. Prices are comparable to south east breakers.
Pre and post facelift tailgates are interchangable, face lift bumpers fit pre facelift, but NOT other way round, lights are one size fits all.
He is literally 1 minute from the Peggy Bedford services on the A4. That's the one with the Total Garage and Mcdognads Drive through. The easiest way to get hold of him is to go to his ebay shop, find his contact number and ring him as he almost always answers first attempt.
HTH, Al. :y
dragonlord
  • luton
Re: Body Panels
« Reply #4 on: 26 May 2011, 14:15:09 »
re the tail gate if you just hit the bumper
it will be due to the rear panel where bummer brackets are
mine push in there when i was rear ended at the lights
once you get the boot open and trim off it usually  knock back prity easy on the omegas
if you not hit it hard enough to bend the floor pan
and it has to be a prity hard hit to do that so unless you really slammed into post
ill bet floor is fine
how bad the bumper i put a 5 inch hole in mine in a tinny 18inch high bollard you couldn't see from in side car
 i had it plastic welded and filled and painted buy a local spot repair guy, a rusty arch done and a scratched sill for 200 quid
the lock jamming will be due to pressure as its on that panel that's pushed in
try one guy with pushing with feet or giving a outward kick from inside car while you try to open from out side
« Last Edit: 26 May 2011, 14:19:27 by outlaw1234 »
Captain Slower
Re: Body Panels
« Reply #5 on: 10 June 2011, 17:16:20 »
Thanks for the advise. Got the tailgate open and managed to get some of the crease out of the panel. Paint cracked unfortunately, so will cover it with some touch up to keep the weather out. If the weather holds this weekend I'll take the bumper off and see if I can bend the metal back into shape. I've been told that if I heat the plastic outer, the crease should come out ok. We'll see. Anyway, thanks for the reply.
Page created in 0.025 seconds with 16 queries.
