Stopping
Started by miggy, 01 June 2007, 22:47:14
miggy
Just looking on the wifes Renaultsport clit 197 forum and there are 2 guys arguing on there on how you should stop when approaching junctions, roundabouts etc.
One says he approaches the junction without changing down the gear box
The other says the correct way is to change down the box to assist braking and to approach the junction in the correct gear.
How do you do it in your manuals. ;D ;D
hotel21
Brakepads are cheaper than gearboxes....
Brake off the speed then select the correct gear for the speed needed to negotiate the hazard safely.
Jay w
I use the gearbox as a suppliment to the brakes, i go down through the box as i approach the junction........
i do the same with the autobox, i will knock it down through the box, save the brakes
QuoteI use the gearbox as a suppliment to the brakes, i go down through the box as i approach the junction........
Hmm.... not sure I can agree with this
Having changed a gearbox on a V6... give me a brake pad change any day!!!
When I drive manuals, I get the car down to the appropriate speed, and then select the gear I need dependant on speed and situation
Broccie - what does Roadcraft say?
miggy
This thread sounds like the one on the renault forum.
I suppose its driver preference, I was tought 30 years ago to change down the box and recently on my advanced driving course.
My daughter recently passed her test and she was tought to change down the box.
I suppose we need to agree to disagree on this one.
:y :y
Dazzler
The correct way is to stay in the gear you are in prior to the roundabout and then block-change down either into 2nd if not actually stopping at the rounabout of if stopped blockchange straight into first. Doing it this way saves the Ozone as well (cough) ;)
miggy
QuoteThe correct way is to stay in the gear you are in prior to the roundabout and then block-change down either into 2nd if not actually stopping at the rounabout of if stopped blockchange straight into first. Doing it this way saves the Ozone as well (cough) ;)
As long as you select the correct gear otherwise the gearbox and engine will end up in heaven.
;D ;D
QuoteThis thread sounds like the one on the renault forum.
:y :y
Ah, it's all friendly banter...
My instructor when learning to drive 6 years ago, although his method was to change down the box as you approach something... told me that he was forced to make us block change when we'd reached the speed required..
Ronald_McBurger
As the forums only qualified and practicing Approved Driving Instructor, I can safely say without fear of contradiction that this is the correct way:
Approach roundabout in whatever gear you are in (4th for example). Slow using the footbrake whilst you assess the roundabout for traffic. Select the gear when you can see if it is clear., ie 2nd or continue braking to a stop and select 1st just before stopping in preparation to starting again.
miggy
QuoteAs the forums only qualified and practicing Approved Driving Instructor, I can safely say without fear of contradiction that this is the correct way:
There you are, query solved.
hotel21
#10
What was that I said again as the first answer to this thread???   ;D   ;D   ;D   :y
QuoteBrakepads are cheaper than gearboxes....
Reads like we are quoting the same thing, Mr McB   :y
James - as above, Matey!!   ;)
Danny
if you're coming to a complete stop, stay in the gear you're in, then when you're slow enough, clutch in and gear straight to first, if you know you dont need to stop, slow down to about 15mph and change to second (roundabouts and stuff)
that's what i do in my manual, as a passenger i'd see people approach a junction and shift down through every gear and it just seems unnecessary
megaomega123
Yeeehaaa!!!   My wife was taught to change down through the gears. I was taught the proper way. Arguement settled.
A roundabout is the same as any other road deviation, brake whilst assessing then select the correct gear for your speed and away you go.  :y
MikeDundee
Personally change down gears, but sometimes just brake and then change gear, depends on situation ;)
Those of us taught 20 odd years ago, with no update training, will probably still use the older gearbox method.  Nowadays, using the brake is the preferred way due to economy, better braking systems, and it brings on stop lamps to warn following drivers.
Obviously, using the gears is still advisable sometimes, such as steep downhill gradients etc...
