Author Topic: omega elite 3.0 engine cutting out...  (Read 2222 times)
Toppo
  • Crosby
« on: 04 June 2007, 10:50:37 »
Hi all  :).... i have an omega elite 3.0...i have a problem with the engine cutting out whilst driving, as you can imagine this can be very scary, its an intermittent problem which might not occur for over a month ...yet can happen 5 or 6 times in a day....the engine generally starts up, if not right away, then after 2 or 3 goes on the ignition  i have had this checked out by two  seperate auto elecricians....sadly as the engine seems to right itself after a few seconds, and is working when they run diagnostic, they cannot specify the fault, evidently the problem has to exist before it can be detected, they have suggested that i take it to Vauxhaul to see if they can run further checks, but i have heard that they can be really expensive, and as i have already splashed out a fair amount of money getting it thru the mot last month, i am not sure if its worth it, i dont know if anyone has experienced this problem at all, but i would really appreciate some advice on this matter, as sadly i have to sell this beauty because of disability and am picking my new car up in July, and as you can appreciate i cannot and will not sell until this problem is solved, I hope one of the omega owners  might be able to offer some advice... thanks...  Toppo  :)
Re: omega elite 3.0 engine cutting out...
« Reply #1 on: 04 June 2007, 10:57:22 »
i'd say the crank sensor is on the way out....check the maintenance guide section for some info. Get it replaced ASAP as it sounds like its on the way out, once failed the car won't start.
Its an easy and low cost job, so don't worry  :y
Toppo
  • Crosby
« Reply #2 on: 04 June 2007, 12:31:07 »
Hi tunnie, thanks for your reply, on my first visit to the auto electrician he fitted what he called a new crank box...would this be the same as a new crank sensor?  Toppo :)
« Reply #3 on: 04 June 2007, 14:22:09 »
I've not heard of a crank box before.
Before replacing kit though, read out the fault codes.
Is this the car that was for sale? What year is it, and how much is it going for?
Toppo
  • Crosby
« Reply #4 on: 04 June 2007, 17:23:19 »
Hi James, yes this is the same one, its late 1996 model N reg.. 3.0 elite  has just passed mot ....renewed rear nearside brake pads... rear offside brake pads....new suspension arm to front offside....new suspension arm to front nearside and new bushes to both front nearside and offside... two new rear tyres...front tyres very good condition ...price i want is £500.00...Toppo  :)
« Reply #5 on: 04 June 2007, 17:32:05 »
Price is about right for someone who wants once (once the cutting out is resolved...)
« Reply #6 on: 04 June 2007, 18:11:28 »
never heard of a crank box before, do the paper clip test and post up the fault codes  :y
Admin
« Reply #7 on: 04 June 2007, 21:36:30 »
Naah, just sell it to me as is.... however it would be for considerably less than £500  ;)
The Administrator.
« Reply #8 on: 04 June 2007, 23:13:39 »
Ignore him, he's had all the bargains.... sell it to me for £25 and let me fit my spare crank sensor and drive away...... ;D ;D ;D
Toppo
  • Crosby
« Reply #9 on: 05 June 2007, 00:16:41 »
Oh My, thank you all for your help in this matter and also your generous offers to buy , but to sell my baby for less than £500 after just paying out £350 on her to get through the m o t (and only 109 thousand miles on the clock , and oh those black leather seats too)..well just the thought of it makes me tremble.....i was tempted by James's offer but after careful consideration ..i managed to control my temper  >:( and hope for a better offer in the future  ;)...now one wonders what laidback means by considerable???  :-/ thanks anyway guys you have been most informmative and helpful  Toppo  :)
« Reply #10 on: 05 June 2007, 00:47:01 »
It's only banter mate ;)
Still, get those codes read - I suspect crank sensor is at fault.
Once you sort that, it will be a lot more sell-able, and you should get that asking price :y
Toppo
  • Crosby
« Reply #11 on: 05 June 2007, 10:50:06 »
Thanks James, i know its banter, and appreciate it all  :P...will do as advised if i can work out what the paper clip test is  :-[ if i fathom it out i will post up codes for everyones kind perusal....thanks again.... Toppo  :y
Admin
The Administrator.
Toppo
  • Crosby
« Reply #13 on: 05 June 2007, 11:10:21 »
Thanks Laidback.. :)
