Pages: [1] 2 3 4 5 6   Go Down
Author Topic: Dishwasher faults  (Read 7911 times)
Dishwasher faults
« on: 01 August 2011, 15:39:30 »
Blows out the RCD (which covers all 3 ring mains :().
Seems to be when well into a cycle, either still when washing, or into drying cycle.
A cold 'prewash' cycle (whatever that is -its a kitchen appliance, me no understandie) works fine.
Is this the normal symptom for a failing heater element?
Re: Dishwasher faults
« Reply #1 on: 01 August 2011, 15:40:01 »
Clearly, the element heats up, as it does get hot in the machine before the trip blows
« Reply #2 on: 01 August 2011, 15:41:10 »
is she getting enough tea?  ;D ;D  :-X :-X :-X :-X
*runs & hides  :D  ;D
« Reply #3 on: 01 August 2011, 15:42:25 »
Certainly has to be high on the list. :y
Pull the connectors off the element and check leakage with a megger or failing that a normal ohmmeter.
Check the wiring between the door and main unit as it bends round the door hinge too. All the flexing often causes the wires to chafe.
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« Reply #4 on: 01 August 2011, 15:46:39 »
Might I suggest fairy liquid and marigolds as demonstrated by a certain other Admin! [smiley=bath.gif]
Been there, fallen over it!
« Reply #5 on: 01 August 2011, 15:47:11 »
Just got to work out how to get the sides off.  6 screws, still no further forward ;D
Where is the element, in the sump?
« Reply #6 on: 01 August 2011, 15:48:00 »
Ooooh, isn't he sexy in his rubber gloves.
"Bend Over, laddie!"
;D
« Reply #7 on: 01 August 2011, 15:50:10 »
I should add, when its hot and blown the trip, it trips out IMMEDIATELY I turn it back on at the wall.
Once cooled, it appears to be OK again on cold wash, and get 1:30 into a 2:30 wash...
« Reply #8 on: 01 August 2011, 15:50:21 »
Yep. Should be able to just tip it onto its' front / back / side to get to the element wiring.
A visual check of the element might tell you all you need to know.
ninjapirate
  • dummer. hants.
« Reply #9 on: 01 August 2011, 15:50:51 »
mine does the same! i gave up and just use my delicate handies
will get around to throwing it out and replacing it one day.
« Reply #10 on: 01 August 2011, 15:59:27 »
Anyone got a FDW70 service manual?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11 on: 01 August 2011, 16:03:16 »
Is this any good TB ?      http://www.manualsmania.com/model.php?model=623a54de44da9349fc29131fa64caa0f9492ce
other rides
« Reply #12 on: 01 August 2011, 16:15:51 »
Washing up is a woman's job. Always has been.....always will be. :)
« Reply #13 on: 01 August 2011, 16:20:05 »
Thats a user guide, freely available from Indeshit directly.  Its the service/repair manual I'm after, as I reckon there is a pesky hidden screw ;D
« Reply #14 on: 01 August 2011, 16:23:31 »
Other thing you can go is disconnect the heater and see if the cycle completes. (and then plumb it into the hot water, give Mrs. TB a tea cloth and relax and have a beer in the satisfaction of a successful "repair" and a reduced leccy bill.) :y
Pages: [1] 2 3 4 5 6   Go Up
