Author Topic: Internet Explorer question  (Read 1447 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« on: 14 September 2011, 21:03:23 »
Hi all, :y
I had to wipe my C drive and reload Windows XP. Why is it, when I open Internet Explorer now, the page opens in a small size about 4" x 3". It means I have to click to go full screen.
On the original setup, the pages, like this forum, for instance opened in a bigger page, not full screen, but as I liked it really. As I use my 22" widescreen as my main monitor, full screen is a bloody big page ;D I prefered the slightly smaller version.
Is there a setting somewhere that you can use to set the page opening size, not full screen, but say about 3/4 screen :y
Sorry for the ignorance on this subject.........
TIA
Tony
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
Re: Internet Explorer question
« Reply #1 on: 14 September 2011, 21:24:28 »
Try dragging the window into a bigger size before closing it. It might open to that size next time  :-/
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #2 on: 14 September 2011, 22:03:07 »
Funny you said that. ive just noticed mine does that since reading your post  :-? :-? :-?
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #3 on: 14 September 2011, 22:49:10 »
    Open a single Internet Explorer window to the smaller size.
    Drag the corners of the window until it completely fills the screen. Do not use the maximize button to enlarge the window.
    Hold down the Ctrl key, and while holding it down use the mouse to click File and then Exit on the toolbar. NOTE: Do not use the "X" in the upper right corner to close the window.
    Internet Explorer should now open in a full window.
    If it still opens to a smaller size repeat the above but this time us the "Shift" key instead of the "Ctrl" key.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #4 on: 15 September 2011, 00:03:24 »
No joy fellas....tried all your suggestions....still get a small page :(
I can remember the 'stretching' way working on the previous loading. :( but won't work now for some reason
Plomien
  • Swansea
« Reply #5 on: 15 September 2011, 07:45:37 »
use firefox or google chrome instead  ;D
mantahatch
« Reply #6 on: 15 September 2011, 08:29:22 »
Try googling it. There are millions in a similar postion. Some people it happens occasionally, some people all the time, and some people it never happens to .
Think it bad programming by microsoft personally.
« Reply #7 on: 15 September 2011, 19:50:54 »
By default, Internet Explorer is supposed to open at the same size it was at the last time it was closed; however, sometimes the default setting gets out of sync, and you need to manually reset it. Here’s how.
1. Launch Internet Explorer.
2. Click one of the window corners and drag it out to completely fill your screen. Do not use the Maximize button.
3. Press [Alt] to view the menu bar (if you are using Internet Explorer 7).
4. Press and hold down either [Ctrl] or [Shift] while selecting Exit from the File menu. Do not use the Close button.
Now when you launch Internet Explorer, it should open in a full window. If it opens in the same small window, repeat the steps but hold down the opposite key in step 4, that is either [Ctrl] or [Shift].
HTH  :y
« Reply #8 on: 15 September 2011, 20:03:30 »
Hi all, :y
TIA
Tony
did you finish loading the updates ? when installing them if ie is open it may create some problems.. or even in registry.. (if there are problems on the disk especially)  and run a full chkdsk imo..
« Last Edit: 15 September 2011, 20:13:43 by cem_devecioglu »
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #9 on: 16 September 2011, 19:51:07 »
Brilliant Cem....cracked it :y
Thanks to all for the suggestions :y
Chkdsk came up with 'repairing missing files' then started IE , did the 'drag' system, and all well :y
« Reply #10 on: 16 September 2011, 20:01:57 »
 :y :y
